Old 06-26-2015, 10:15 AM   #71
Oaklevel's Avatar
I understand not wanting to run grossly overly over weight but what I do not understand is why so many want to base their weights on dry weight or dry hitch weight??? Yes it is a starting point but that is all it is and only when it leaves the factory with no propane or dealer added options. To me watching gross weight is more important. Also that is what I am required to tag the trailer .............
THs are granted a different breed but my dry weight is advertised at for my year at 9,200, and the dry pin weight at 1766 lbs.. My actual dry weight with options was yellow sticker 9688lbs ............. If I based my truck on dry weight I would be in serious trouble............ the gross weight of the trailer is 14500.
On the scales the camper was about 13500 making a 20% pin weight around 2700.... dry listed 1766 big difference. I doubt 20% is true for this trailer but it can vary depending on the weight distribution at the time.............. but never worried about it. But that is another story........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 06-26-2015, 04:48 PM   #72
CWSWine's Avatar
I understand what you are saying but this was my thought process. If the dry weight was 10,000 lbs and the dry pin weight was 20% of that number. If I added 1500 lbs of cargo above dry weight and it added 20% to 25% of that went to pin weight my pin weight would be 2200 or max of 2500. What happened I added 1070 and my pin weight went to 2780 and that not loaded to go camping. My thought process was flawed hence the title Weigh your RV you might be surprised.
Then people take their CCC off the yellow tag on the truck and match that to estimated pin weight of the RV. The CCC of truck yellow tag could be couple hundred pounds to as 800 lbs or more two high if the truck is loaded ready to go camping. That could case a gross over weigh condition.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 06-26-2015, 05:24 PM   #73
Tonkatoy77's Avatar
So you run with 3800 lbs of gear in your trailer? DAMN!!! Do you live in it? I have two toddlers, and don't think I would ever take that much stuff camping.
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 06-27-2015, 09:51 PM   #74
Oaklevel's Avatar
Yep...... Golf Car & extra (apt / dorm size) Frig. small compressor in toy room ...... for starters. The garage its self is rated to carry 2500 lbs...... Thats before the normal camping gear. Toyhaulers carry such a variety of added weight & configurations that can get one in trouble quickly if not careful about weights....... won't even start on extras the DW brings for the GS.
1966 Mustang GT
1986 Mustang SVO
weight
