Old 04-20-2016, 11:25 AM   #11
Blackrock's Avatar
Okay my bad. I had to decipher my hen scratching in my note book.
Air bags are at 20 psi and truck is leveled out (no squat) I'm happy with the way it pulls and handles.
Front Axle: 3040
Rear Axle: 4400 with
Trailer: 5740
Total: 13,180
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 04-20-2016, 11:37 AM   #12
Are you happy being over your GVWR and RAWR by 500lbs? Not a huge amount but still concerning. I would make sure my tires on the truck are at max psi.
Remember anything you add to the front of the 5th wheel will add to the weight on the rear axle. So in the end you could be 700lbs+ over on the RAWR and GVW.
Most these 1/2 ton towables are only 1/2 ton towable when empty. Once you load them up you'll be in 3/4 ton territory.
goduc is offline   Reply With Quote
Old 04-20-2016, 11:48 AM   #13
ManlyMan's Avatar
Too bad you bought a Laredo which is Keystone product (Thor Industries.) Now you can't go to any of the FROG rallies.
ManlyMan is offline   Reply With Quote
Old 04-20-2016, 12:34 PM   #14
CWSWine's Avatar
I see from another post he headed to Alaska and with all the stuff that will require I bet he is closer to 1,000 over Rear Axle Weight Rating. I won't want to be that far over and bouncing down the pot hole roads going up the AlCAN highway and over some of those mountain passes but that's me.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-20-2016, 01:02 PM   #15
B and B's Avatar
I Towed heavy with my F 150, it was over by 1000 lbs but under on rear axle maximum. I traded. As far as a Alaksa Tow to each there own but that is alot to put anything though that overloaded. Hopefully the OPs road goes on forever and the party never ends.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-21-2016, 12:48 AM   #16
Live and learn I guess. Some just learn the hard way.
Old 04-21-2016, 08:25 PM   #17
Blackrock's Avatar
This truck with the heavy tow package has a rated payload of 1830 lbs. By my figures with a empty rear axle weight of 2600lbs and a loaded weight of 4400 lbs. that gives me a pin weight of 1800 lbs. Granted that only gives me a 30lb. margin and I am good with that. A trailer gross weight of 7450lbs before loading 500lbs of personal gear bringing it up to a round 8000lbs is still well under the 10,500 tow rating.
Old 04-21-2016, 08:46 PM   #18
CWSWine's Avatar
Your payload is 1830 minus the weight of the hitch 200 plus you and the wife and dog at 350 lbs misc stuff in the truck and truck bed lets say another 50 lbs. Now that 1830 is down to 1230 left over for your 1800 lbs pin weight. So that leaves you over weight by 580 lbs. Not to mention that you are over your Max Axle Weights Ratings by 500 lbs using your base numbers.
Great place to run numbers.
http://towingplanner.com/Calculators...50&bd=50&ct=FW
Using your 1830 lbs Payload Capacity and the numbers come from the link above.
You're adding approximately 700 lbs. to the truck. You have 1,130 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 4,520 - 5,650 lbs.
Old 04-21-2016, 09:39 PM   #19
Ram doesn't make a Heavy Duty option for the 1500.
Show me that data. You might get 1800+lbs for payload in a stripper Tradesmen reg cab 2wd. But not in your truck.
Post a picture of the placard on your truck that shows payload capacity. It's on the door jamb.
Old 04-21-2016, 09:47 PM   #20
Who Dares, Wins
doc73's Avatar
Won't add fuel to this fire... I have decided to no longer partake in the weight debate of right and wrong. NOt worth the chest pains
But my (well patrol truck) 15 Ram 1500 CC SB Hemi is 1055 on the payload according to the yellow sticker. It does have the Rambox though so that might kill a few Lbs.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
