Old 10-14-2013, 02:49 PM   #21
Brother Les's Avatar
Do you know how funny that sounds if it was not so serious?
The new truck just did not pull that much better
I am thinking that the trailer brakes were dragging all the time and that is why it feel like it had low power
Just guess how much power you will have when your brakes are not dragging....
I am also concerned about damage to the trailer brakes since they had 3.56 volts to them all the time.
I had a camper for over 10 years and talked to an RV service manager about changing out the break pads. He asked if I had any problems, which I said no. He said that the pads could last the life of the camper if used right.
These are electric, not hydraulic, which I think will not lock up the camper with the low voltage that you had. You may have burned some pad off, but I think that it will be fine. Find out why the voltage was low and set the breaks correctly. Then see how great your TV will pull that TT.
Brother Les
Old 10-14-2013, 02:58 PM   #22
Just got off the phone with the dealer to make an appointment to have the controller checked. They are sending someone to pick up the truck and hope to have an answer this afternoon.
I already have an appointment at the local RV repair shop for some other warranty issues, so I'll have them check the brakes while it is there.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 10-14-2013, 03:05 PM   #23
AquaMan's Avatar
You shouldn't even realize that trailer is behind you! If you were getting voltage without brake being applied, you have a problem. The integrated brake controller in the Chevy/GMC trucks are great when they are working properly. You should also have your hitch set properly, as the truck has the ability to sense a sway (although it has to be fairly severe) and will automatically apply trailer brakes to correct. It works in conjunction with the anti-locks. At least that's what the manual says.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 10-14-2013, 05:46 PM   #24
Incheon, S. Korea
BigBaron's Avatar
The dragging brakes would slow you down. I would think a duramax could pull trees out of the ground! Are you using the integrated brake control? It sounds like a different controller is in order after a wiring check.
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 10-15-2013, 04:32 PM   #25
They installed a new ITBC module and now it works great. Offered to pay for trailer brakes if needed. Have an appointment to have the TT brakes checked. The integrated trailer brake is so smooth compared to my old system no more jerking when brakes applies at slow speeds. Truck pulls like crazy .
John And Mary
2013 XLR 27 HFS
Old 10-15-2013, 04:53 PM   #26
phat phrog stunt crew
another oil burner convert. next .....
dwaynerz is offline   Reply With Quote
Old 10-15-2013, 05:44 PM   #27
Denver, CO
garbonz's Avatar
Originally Posted by Iwannacamp View Post
Amen to maintenance. If it says 7500 miles then do it at 5000. Synthetic oils or blends are the preferred oils. I am personally sold on Schaefer oil products. I think they are the best made. They have a fuel treatment that will increase fuel mileage 10% and better. Yes, it will. Neutra for gas and diesel. Diesel treat 2000 for diesel. Go get some. They have been in business for about 175 years. Name another one who has.
175 years? I didn't think they had oil back then?
2017 Fuse 23T
Old 10-15-2013, 05:47 PM   #28
Denver, CO
garbonz's Avatar
Originally Posted by Ida Ratherbe Camping View Post
Kinda glad my old standby 5.9 doesnt have to clean its exhaust filter. Makes me want to keep it longer. Checking into the Schaffers, doesnt look to common around here. A NAPA store 100 miles away sells it according to the web site.
X2 for my 07 Dmax. No cleaning for me..
2017 Fuse 23T
Old 10-15-2013, 06:18 PM   #29
AquaMan's Avatar
Use that exhaust brake, and you'll find yourself hardly using your brakes at all! Coming off an interstate, my truck's exhaust brake will slow my rig to the point I just have to apply at the very end of a stop.
