Old 06-23-2015, 11:13 AM   #1
CWSWine's Avatar
Went to get an extra key and....
Stop by the Ford to pickup a third key for the truck and was told that it $295.00 plus if you want them to program the key to work with the truck it would be a 40.00 programming fee. I ask about key with no electronics (valet key) just to open the doors locks and start the truck – in 2015 there is not such thing. The valet is standard key that you use the trucks onboard computer to setup the way you want it. I’m not sure about other years mine is 2015.
When I comment on the cost he said that a guy was in this morning with crack tail light lens on 2015 F150 with blind spot warning system and the taillight is sealed unit and you have to replace the entire unit for a cost of 895.00 plus the computer will mostly likely take a reset. He said that was typical cost of most taillights that have the blind side warning system in the taillight (not the backup warning sensors they are in the bumper). You wonder why insurance is so high! What happen to the days that there was 4 screws and 50.00 cost of just a lens.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 06-23-2015, 11:32 AM   #2
It's the price of progress.
Iwritecode is offline   Reply With Quote
Old 06-23-2015, 12:57 PM   #3
schrederman's Avatar
No wonder Ford didn't need a bailout!!!
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 06-23-2015, 05:04 PM   #4
jaibyrd's Avatar
There are other sources for additional keys then going with Ford. We have a local company ekeysforcars.com. part of their business model is to be a more cost effective solution than going back to the dealer.
I haven't used them yet, but a neighbor has. Not sure how much he saved, but the key works.
Snyder Family - Pelham, NH
2015 Sunseeker 3170DS
jaibyrd is offline   Reply With Quote
Old 06-23-2015, 07:33 PM   #5
When I was in Clovis, NM, a local locksmith made me a key for my Expedition for about 30% of what the Ford dealer wanted... That's been a few years ago, but not that many.
Old 06-23-2015, 08:15 PM   #6
My 2010 F150 I got one at Walmart. The first Walmart I went to said they could not do it, 2nd one near my brothers was $65 and works just fine.
Uncle Spike is offline   Reply With Quote
Old 06-23-2015, 09:46 PM   #7
Thekipkers's Avatar
With the key fob being integrated into the key and the ford passive anti theft system the keys have become outrageous in cost.
Not sure anyone has the 2011-2015 keys any cheaper or not. The new keys can be programmed using the on board computer to limit speeds, add seat belt notices and such for younger drivers, you set a primary key and then program each other key after.
SK2 Camping Crew
2010 Ford F-350 Lariat
2015 Heritage Glen 356QB
Thekipkers is offline   Reply With Quote
Old 06-24-2015, 12:53 AM   #8
You can get a standard PATS(passive anti-theft-chipped) key(one without the buttons),this key would be a lot cheaper than the one with the buttons and would be able to start the truck. You can also get a non PATS key cut for a valet key. If the customer spare key programming feature is enabled, then you would be able to program the third key yourself. the procedure to do this is as follows: you will need the 2 factory programed keys, put the 1st key in the ignition and turn the ignition on for a minimum of 6 seconds and the turn the ignition off and remove the key, with in 10 seconds put the 2nd key in the ignition and turn the ignition on for a minimum of 6 seconds and then turn the ignition off and remove the key, with in 10 seconds put the new key in the ignition and turn the ignition on for a minimum of 10 seconds, the door locks may cycle to lock and unlock. The new key should now be programed. If the new key did not program, the customer spare key programing feature may be disabled and you would have to get the dealer to enable it. If the key did not program try a second time. I will try to get the key part numbers tomorrow at work for the standard PATS key and the key used for a valet key. I'm a service tech at a FORD dealership. Hope this helps.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 06-24-2015, 07:10 AM   #9
Georgia Frog Rally 2018
aceinspp's Avatar
Ya And everybody loves new technology . Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-24-2015, 09:55 AM   #10
The key numbers from Ford is: PATS key- C25937,non PATS key(valet)- H75.
09grizzly1
09 Grizzly 700 EPS
