Old 04-14-2015, 08:44 AM   #31
ferguson65's Avatar
Originally Posted by Zolin View Post
Tongue Weight (TW) refers to the tongue weight of your trailer and the weight of the cargo that sits behind the rear axle of your vehicle.
Trailer TW is measured using a tongue weight scale
Typically, about 10 to 15 percent of GTW
Etrailer has this wrong. Trailer tongue weight, and trailer weight limits printed on the hitch are the capacity for the receiver hitch itself. Anything in the bed of the truck/ suv goes against payload.
Putting a ton of weight behind the truck axle will surely amplify squat and make the setup on the WDH bars different, but it doesn't take away from hitch capacity.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 04-14-2015, 09:11 AM   #32
Herk7769's Avatar
Originally Posted by Crockett View Post
I would think items in the bed would be independant of tongue weight and acceptable as long as gvwr was not exceeded.
I was having some trouble following all the posts
Tongue weight must only be determined with the spring bars removed as it is not changed at all with them in place; only what axles support it. The frame and receiver of the truck and trailer "see" the unsprung tongue weight.
Determine actual camper weight
Sum disconnected truck axles and subtract from connected total rig weight
MUST be less than GVWR of camper
Determine actual tongue weight
Sum unsprung loaded truck axles and subtract sum of disconnected truck axles
Must be less than receiver, hitch, and truck's maximum tongue weight ratings
Weights to compare:
(with spring bars on)
Sum of loaded truck axles less than Pillar Sticker GVWR
Sum of trailer axles less than axle rating x number of axles
Rear truck axle less than GAWR
Front truck axle less than GAWR
Lots more can be determined using your 3 weighings at the scale.
Name:	WD Hitch and GVWR.jpg
HAM CALLSIGN - KC3FFW
Old 04-14-2015, 09:20 AM   #33
Herk7769's Avatar
Truck payload is everything in or on the truck (except for a full tank of gas and a 150 pound driver).
While actual tongue load is used to determine hitch load; the distributed tongue load is used when calculating payload. This is because a fraction of the actual tongue load gets shifted to the front and camper axles when the tension is applied to the WD hitch.
Old 04-14-2015, 09:42 AM   #34
Herk7769's Avatar
Tongue Weight (for weight distribution) = trailer tongue weight + vehicle cargo load behind rear axle
As always the devil is in the details.
What they are saying is "correct" but not germain to the discussion at hand.
When determining the actual amount of load to be distributed by a WD hitch; it is true that everything "aft" of the rear axle will squat the truck. It has nothing to do with tongue load which is weight added to the truck through the receiver.
Weight added aft of the rear axle is just added to payload carried forward of it.
Where the load carried aft (in the bed) could be a factor is if the maximum deflection of the torsion bars needed to level the load overloads the front truck axle or the camper's axles. In this case moving heavy items up against the tailgate (like gas cans!) forward of the rear axle centerline can require less distribution and relieve some of the load on the distributed axles.
Old 04-14-2015, 09:47 AM   #35
as I understand the term "tongue weight" it refers to the maximum amount of weight that can be distributed on the hitch and must include cargo behind the drive axle...
Tongue wt is the weight on the tongue and has nothing to do with what is in the truck bed either in front of the axle or behind the axle. You measure the tongue wt with the trailer unhooked from the tow vehicle.
What the wdh bars have to contend with DOES include what is behind the axle of the truck as well as all the wdh hitch head components.
Old 04-14-2015, 09:47 AM   #36
Your weights are darn near perfect from a WDH standpoint. I wouldn't change a thing, certainly NOT increasing pressure on your srpingbars. Your front axle weighs 60 lbs more than unloaded. Can't get much closer than that. The goal is to restore the front axle weight without going over. You are over by 60 lbs but I would call that OK.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-14-2015, 09:53 AM   #37
I always measured wheel well height before and after hitching and adjusted the bars to get the same measurements hitched as before hitching.
Old 04-14-2015, 09:59 AM   #38
Herk7769's Avatar
Great way to measure tongue weight without hooking up:
ID:	74231   Click image for larger version
Old 04-14-2015, 10:07 AM   #39
WolfWhistle's Avatar
OC x2. Measuring is to get the set up right; weighing is where you find out you bought the wrong trailer for your truck, or vice versa.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 04-14-2015, 10:20 AM   #40
Crockett's Avatar
with todays tongue weights, id be concerned about what could be something north of a 300 lbs one dimensional point load on a bathroom scale. how about a 2x2 in place of a pipe, so nothing moves, and a board to distribute load on the scale. this technique was developed before slides when average weights were closer to 400-500 lbs. unless, of course, the bathroom scale has evolved as well to accomodate the increase in weight...NVM
Crockett is offline   Reply With Quote
scales
