Old 07-28-2013, 11:39 AM   #1
Blackrock's Avatar
Whadda ya think ?
Wife and I are planning a short trip to get out of town before I start a new job.
The trip is a 30 mile run to the base of the mountain then up from 3500ft to 9000ft in 20 miles of steep climbing and lots of switchbacks.
So here is my plan. Load a 1000# UTV in the truck. Use a 12" hitch extension and a regular ball. No sway control or weight distributing hitch because of all the windy roads.
I have firestone air bag helpers as well.
Truck is a '01 F150 7700 package 5.4 and 3:73 gears. Trailer is a Forest River 25DS with a hitch weight of 400# and a dry weight of 4200#.
I used to use the extender with a big pop up like a BR23SC with a 600# ATV on the trailer deck and the 1000# UTV in the truck bed. Pulled it OK anywhere I went.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 07-28-2013, 11:52 AM   #2
Dave_Monica's Avatar
Am I correct that your truck has the HD payload package with a GVWR of 7700 lbs?
It sounds like you'll be right up there in payload capacity. Do you have air bags on the truck to help level it with the weight of the ATV?
I admit that I don't understand why you'd opt to not use the W/D and sway control...the windy roads wouldn't prevent their use.
Dave
Old 07-28-2013, 12:05 PM   #3
Blackrock's Avatar
Yep, got air bags on the truck and the W/D hitch and sway bar will be carried along if needed. This road up Mt. Graham is 20+ miles of switchbacks with a rapid rise in elevation.
For reference Delco Moraine used this road as a test bed back when they were experimenting with non asbestos brake lining materiels. Run to the top and then back down watching the instruments reading the brake temps. This road has a greater elevation change from valley floor to the top than Pikes Peak. And it is downright cool and beautiful when you get on top.
Old 07-28-2013, 12:17 PM   #4
Triguy's Avatar
Blackrock,
Can you explain your concerns over why you wouldn't run with your WDH?
More importantly, can you tell us what your Ford's hitch rating is without the WDH? I "believe" its limited to 600lb tongue weight. Dependig on how much you load into your trailer (cargo, water, propane, batteries, etc), you will be well over the dry weight of 4,200lbs and your TW may be over your truck's hitch rating without the WDH.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 07-28-2013, 12:28 PM   #5
Blackrock's Avatar
Originally Posted by Triguy View Post
Blackrock,
You could have something there. That is why I am bouncing ideas around you fellers.
I will have one full propane tank plus two grp 24 batteries on the front.
So I will see how the W/D hitch setup will work on the windy road. I know I will be either at max or a little over for this short haul. I wouldn't want to go across country set up like this. But I want to take EVERYTHING up there in one trip. Last time my daughter drove my CJ5 up for us all to run around in.
Old 07-28-2013, 12:32 PM   #6
Triguy's Avatar
Got ya! Sounds like a great trip.
The reason I would use my WDH (besides staying within your truck's hitch rating) is to also add more weight to the front axle. I find that running without the WDH will take off too much weight and the steering becomes too light for my taste.
Scott
2012 Shamrock 233S
Old 07-31-2013, 01:55 PM   #7
schrederman's Avatar
I put over 300K miles on an '02 F-150-7700. I believe you will be OK if you use the WDH. I pulled large portable generators to mountaintop radio sites all over central New Mexico in nasty weather, with lots of weight in the bed. I am sure I never had 1000# in the bed, though. The generators had a 300# TW.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 08-03-2013, 06:23 PM   #8
Blackrock's Avatar
We are back home after a great trip up Mt Graham. Weighed out at 12,650# total and the truck pulled that load up to around 9,000 ft elevation with no problem. We had 10 miles of dirt mountain road that was pretty rough in places but the trailer took it real well. Had fun running the trails with the Polaris Ranger.
