Old 02-13-2019, 07:42 AM   #1
What 5er are you towing with your 3/4 ton
I have upgraded my tow vehicle from a 2010 Toyota Tundra 4x4 with the 5.7 to a 2018 Ram 2500 limited 4x4 with the 6.7 Cummins. We are looking to get a new 5th wheel in the 34 to 40 foot length. I would like suggestions from those members who tow with a 3/4 ton vehicle. We would like to find one with with front or rear living. The advertised towing capacity is 17,100 lbs
We have always and will continue to tow with empty. Fresh, grey and black water tanks. Extra weight will be the usual inside items, propane and maybe a few sticks of firewood.
We like the Grand Design 379FL GVWR 16000lbs
Scott Thompson is offline   Reply With Quote
Old 02-13-2019, 08:03 AM   #2
We have the same truck.
Unfortunately the payload of that truck limits hitch weights!
Realistically, according to the sticker, it is around #1600 lbs. I weighed it.
I would recommend the Anderson hitch to save weight. Also works well.
I am over sticker like #500. But, under axle/tire capacities. Tows well.
Been in 40 mph winds. It was fine. Stops well.
tomkatb is offline   Reply With Quote
Old 02-13-2019, 08:47 AM   #3
I tow a heritage glen 372 rd with my ram 2500. 43 foot ultra light. 5 slide elevated rear living 11k pounds.
Kimber45 is offline   Reply With Quote
Old 02-13-2019, 08:48 AM   #4
frank4711's Avatar
I will be towing this with my 2019 Ram 1500 Rockwood Ultra Lite 2898KS - Ultra Lite Fifth Wheels Travel Trailers / Fifth Wheels by Forest River RV Yes I know I will be at max on my payload which is 1855 .... and under about 900 on towing which is 11660 .... go ahead a judge me I am use to it on here ....
frank4711 is offline   Reply With Quote
Old 02-13-2019, 09:48 AM   #5
My recommendation.
Weigh your truck, full fuel and passengers. Get front and rear axle weights.
Determine Rear GAWR by looking at sticker on door jamb. Subtract actual Rear Axle weight from GAWR. That is the remaining axle weight capacity you have to accommodate the 5er pin weight, and hitch.
Assume ~200 lbs for hitch if you are getting a conventional one. 60 or so I believe for a Andersen Ultimate.
In my planning, I am assuming worse case that I will eventually load up the 5er to the GVWR. Pin Weight estimates range from 20-25%. Split the difference. 16,000 GVWR times 22.5% = 3600 lbs.
This worse case scenario for pin weight should be below your RGAWR. Yes, you will clearly exceed payload, but many folks (myself included) focus on the RGAWR and to a lesser extent, the payload.
If you have remaining capacity of at least 3600 lbs rear axle, after weighing truck loaded with passengers and fuel, then you should be good to go. I suspect you won't, as the RAWR is probably 6500 lbs.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
walaby is offline   Reply With Quote
Old 02-13-2019, 10:21 AM   #6
Jjsav's Avatar
First This (w/ tundra):
Then This:
Now This (w/ Anderson hitch!):
2018 Jayco Eagle 355MBQS, Andersen Ultimate Hitch
2013 Rockwood 8281SS 5W, Reese Revolution (sold)
2016 GMC 2500 Denali HD 6.6 Diesel
2016 Victory Cross Country Tour
2012 Toyota Tundra Crew Max (sold)
Jjsav is offline   Reply With Quote
Old 02-13-2019, 10:47 AM   #7
Ejs4029's Avatar
Looking at the Grand Design 379FL your going to be way over on payload looking at the spec's that 5er has almost a 3,000 hitch weight dry....
My guess is your payload is going to be under 2,000lbs with your RAM 2500 since it's diesel with the limited package with all the bells and whistles and 4x4 this is going to severely limit your choices in 5th wheels you really needed to go with a 1 ton to even consider that Grand Design.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 02-13-2019, 10:56 AM   #8
Jim34RL's Avatar
I have a 2008, 6.7L Cummins Dodge Mega Cab, 2500 pulling a 2016 34RL Cedar Creek 5th wheel trailer. The truck is not a stock model at all. I am running 60HP/120 lb.-ft. TQ over stock, TB exhaust, with gauges to monitor the EGT's, Boost and Transmission temps, with duel fuel filters, Mag-Hytec covers on the differentials and transmission for extra oil capacity and cooling. My tires are Nitto Dural Grappler LT285/70R/17 126R tires which are rated for 3750 LBS @ 80PSI.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 02-13-2019, 11:15 AM   #9
Denver To Yuma In 90 Days
I purchased my Chevy 2500HD gasser to be overkill for my previous TT.
When deciding to get a 5'ver, I did the not-so-popular thing...
That was to buy a 5'ver that was actually within the tow ratings of my new 3/4-ton truck with room to spare!
It is 33-feet long and weighs in at 9500 pounds loaded and with 1/2 tank of fresh water and some fluids in both the black and gray tanks (maybe 1/3 full).
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is offline   Reply With Quote
Old 02-13-2019, 11:43 AM   #10
Why didn't you get a 3500? You will be over the trucks CCC and RAWR with that Solitude.
You should post your question on the GD owner forum in the Solitude section. I think you'll find out that GD's brochure weights are under the shipped weight.
I tow a lot less than that with an 18 2500 6.4 4.10. My pins only 1800 lbs. the Ram 2500 coils aren't as solid as the previous model leafs. I towed the same exact 5er with a 12 CTD 2500 and it was a more solid tow.
I'd seriously think about something in the 1800-2000 dry pin weight.
FWIW my 1800 lb pin drops the rear 2". I can't imagine dropping another 1500-1800 lbs in the bed. You still have to add the hitch, propane, batteries and all the other stuff you carry in front of the axles.
goduc is offline   Reply With Quote
5er, towing
