Old 03-15-2021, 08:46 AM   #1081
Insert witty title here
I applied some black silicone around the lights on the cab roof to stop a rather persistent water leak.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 03-15-2021, 08:46 AM   #1082
CentralMePistol's Avatar
Originally Posted by chriscowles View Post
And a cold air intake does what?
Well... like it sounds it (in theory) provides colder air to the engine. Which improves performance.
In practice I would say it provides marginally colder air but much better air flow. I can say I’ve seen an immediate improvement in gas mileage.
2018 Cherokee 274DBH
2015 Chevy 2500 4x4 Crew Cab
Recurve R6 WDH w/Sway Control
Days Traveled:2021-51 / 2020-43 / 2019-37 / 2018-30
CentralMePistol is offline   Reply With Quote
Old 03-15-2021, 04:41 PM   #1083
Mch5jdm's Avatar
Whaaaa hoooo!Click image for larger version
Let’s go camping!
Mch5jdm is offline   Reply With Quote
Old 03-28-2021, 11:48 PM   #1084
Retired FF
wrogers's Avatar
Traded it for this:
2021 F450 "The Beast"
ID:	250677   Click image for larger version
2019 Heritage Glen 356QB
2021 Ford F450 DRW 4wd
wrogers is offline   Reply With Quote
Old 04-03-2021, 02:53 PM   #1085
Camping the Natural State
Sumos
Sumo Springs installed and they made a huge difference. Stops the bucking and helps with sway.
ID:	251101   Click image for larger version
ARhappycamper is offline   Reply With Quote
Old 04-03-2021, 04:00 PM   #1086
Busted the 5th wheel yesterday, but received the new door latch I have been waiting for and replaced it on the Drivers door. Door closes with a nice Thump now, and no more jiggles, wiggles, squeaks and thunks. Glad it was something as simple as the latch, because a misaligned door that flops around is not an easy fix.
Bhrava is offline   Reply With Quote
Old 04-07-2021, 04:29 AM   #1087
Sumo Springs
Installed the Sumos. No load -
ID:	251399   Click image for larger version
Old 04-07-2021, 04:32 AM   #1088
Sumos cont -
Loaded trailer tongue on hitch ball -
ID:	251401   Click image for larger version
Old 04-07-2021, 05:01 AM   #1089
Originally Posted by Mch5jdm View Post
Whaaaa hoooo!Attachment 249785
Where did you install the Black Tank in your "Tow Vehicle"? Youroo!!
Old 04-07-2021, 08:46 PM   #1090
Virginian's Avatar
I also installed Sumo Springs on the F-150 today. Didn't have a particular need to, but a lot of research makes me think they'll give me a more enjoyable towing experience on the 7,000 mile trip coming up soon.
Haven't hitched the trailer with them yet. Plan to do that tomorrow to see if I need to adjust hitch height.
2019 Wolf Pup 16FQ - bought new 3/2020
2013 F150 5.0 STX SCab 4x4 SB/3.55 rear/tow pkg./36 gal. tank/1695 Payload/7350 GVWR
Andersen Hitch
Virginian is offline   Reply With Quote
Old 04-07-2021, 08:58 PM   #1091
steering box stabilizer, tighten it all up
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
railroaderone is offline   Reply With Quote
Old 04-08-2021, 07:06 AM   #1092
Installed a new cold case radiator on our 2012 Yukon XL Denali and took the alpha wolf out for a tow on the highway in 85° weather. Temp never got above 217° on the hills where it used to get up to 237° in similar ambient temps. Measured via OBD2 data stream. Fabulous! And with the Trucool transmission cooler, the transmission never got above 170°. Good to go for the summer.
"If I can't fix it, I can fix it so it can't be fixed"
2012 GMC Yukon XL Denali - Silver - 117K miles
2007 GMC Yukon XL Denali - White - 217K miles
2021 Alpha Wolf 26DBH-L
Geotrash is offline   Reply With Quote
Old 04-10-2021, 04:31 AM   #1093
You will most likely need to adjust the hitch height on the trailer tongue, not the actual hitch because your rearend of the truck won’t go down as much with trailer on the ball. Probly raise the brackets on the trailer a notch or 2.
Old 04-10-2021, 05:55 AM   #1094
While it’s a possibility that changes might be needed, I installed sumos on my 2014 Tundra and then a 2014 F-150 and no adjustments were needed.
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
moose074 is offline   Reply With Quote
Old 04-10-2021, 03:08 PM   #1095
I installed Roadmaster Active Suspension and while I was at it, put an Extang Trifecta 2.0 trifold cover on the back of our 2015 Ford F-150 4x2 SC. Looked at the Summo Spring setup but for the money I felt the RAS was well worth it. Unloaded ride and handling is a dramatic change and pulling our 6300 # loaded TT really changed. What they advertised about the RAS is not hype, I experience a much more enjoyable tow with this addition and the bedcover has quieted the interior noise in the cab. Highly recommend both!!
2021 Rockwood MiniLite 2507s
2015 F 150 SC 2.7 EB 3.73 Equal-i-zer WD hitch
Reno8220 is offline   Reply With Quote
Old 04-10-2021, 03:18 PM   #1096
BTW no changes made to my Equa-I-Zer WD hitch as of yet and a great 300 mile tow to out next stop. RAS only raised the rear of the truck by 1/2 “ unloaded and my loaded height trailer and hitch attached is less that 1/4 “ difference.
Just started a trip from Fla around the US of A and back that will take us to the Grand Canyon, Utah, Yellowstone, the Badlands, the UP and lower Michigan, the Adirondacks, White Mountains and Bar Harbor. Then back south before the snow flies.
The RAS should help a lot.
Old 04-10-2021, 04:20 PM   #1097
Mandog's Avatar
Cleaned the throttle body and replaced the fan clutch with a sever duty one. Was heating up some when pulling hills. Being a 2005 2500HD Silverado it’s about time for this service. Only 44,000 miles though. My next addition will be the Roadmaster active suspension upgrade.
Mandog is offline   Reply With Quote
Old 04-10-2021, 04:28 PM   #1098
Originally Posted by CentralMePistol View Post
Yesterday I had a chance to install a cold air intake on my Chevy 2500 gasser. Immediately saw an increase in gas mileage around town... and a nice purr when you get into the gas. Definitely worth it... especially if you have a little helper thanks loves to work on Daddy’s truck!
Before
Attachment 249696
After
Attachment 249697
Installed a K&N cold air on my 2014 Ram 1500 some time ago. Removed it recently and reinstalled the factory unit after I discovered substantial dust and dirt in the intake tube while cleaning the filter. Did not notice improved performance or fuel economy with it installed.
Roberte52 is offline   Reply With Quote
Old 04-10-2021, 11:07 PM   #1099
What did you do to your tow vehicle today?
Went to town. To get pallet of concrete came home with a 2021 3500 Ram Laramie not sure how it happened yet and plus no concrete.
Old 04-11-2021, 02:50 AM   #1100
I feel I now don't have enough tension on my spring bars and they are not level.
2021 Rockwood Ultra Lite 2614 BS
tow vehicle
