Old 05-26-2016, 02:10 PM   #1
What do you guys think.
Xlr 30hds
Went to scale today, loaded for trip.
Weight with w/d bars on
Steer; 3900
Drive:5320
Trailer :7980
Gross: 17200
No weight bars
Steer: 3620
Drive: 5720
Trailer:7860
Gross : 17200
Just truck
Steer: 4240
Drive: 3580
Gross 7820
I think I'm over on tounge weight. Truck is a 2012 f250 gas. Hitch is equalizer 14000, 1400. What do you all think
dennismo is offline   Reply With Quote
Old 05-26-2016, 03:27 PM   #2
fonzie's Avatar
Post your truck data so people can give you proper feedback....example below....
Name:	Ford door jam stickers.jpg
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-26-2016, 03:38 PM   #3
Regardless of TW you need to move more weight to the front axle.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 24 nights camped
Teamfour is offline   Reply With Quote
Old 05-26-2016, 04:01 PM   #4
clr
As I read your truck your front axle is rated for 3750 pounds and the rear axle for 4800 pounds. Per your weight ticket the truck is carrying 3900 pounds and the rear is carrying 5320 pounds. So your front axle is carrying 150 pounds more than its rating. The rear axle is carrying 510 pounds more than its rating. Your weight on the rear axle with no WDH is way over the capacity of the rear axle by 920 pounds. So no change to the WDH will be able to correct this.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-26-2016, 04:09 PM   #5
That sticker is not for the op's truck, just an example of what op should post...
2016 Siverback 33IK
Old 05-26-2016, 05:23 PM   #6
Not sure how to post pictures. Front gawr is 5200lb
Rear gawr is 6100lb. Gvwr is 10000lb
Xlr hyperlite 30hds couch, party deck, pass thru dinette.
2012 f-250 crew cab 4x4 6.2 v8
Old 05-26-2016, 07:02 PM   #7
clr
My bad sorry for the mix up, I thought the truck sticker was for the OP truck.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
Old 05-26-2016, 07:27 PM   #8
clr
Using the right numbers it does seem like the tong is very heavy for a TT. With no bars you have 1520 # of weight on the truck and with the bars you have 1400 # of weight on the truck. But a TT normally places about 10% of its weight on the tong in your case that would be 786# but you have almost twice that weight. Your truck is fine with this weight, your hitch if only 1400# is right at or just above its tong capacity. I would try moving some heavy items to behind the TT wheels if I could to lessen the tong weight.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
Old 05-26-2016, 07:44 PM   #9
And that will effectively move some weight back to the front axle.
Lee and Anne
Old 05-26-2016, 07:45 PM   #10
I forgot, I had a half tank of fresh water also. This is a toy hauler and without bikes in the back is tounge heavy. We're heading to Colorado for two weeks without much in the toy hauler part. I need to figure out what to put back there...
