Old 03-25-2012, 07:45 PM   #1
Newbie
pg_rider's Avatar
What do you think of my before-and-after numbers with the Equal-i-zer?
Finally was able to measure the front and rear heights of my Honda Ridgeline with and without the Equal-i-zer hitched up. I was afraid the technician at RVW hadn't optimized my setup when he hastily installed it on a cold winter day at their lot. However, after measuring the effect of the weight distribution, as well as the level-ness of the trailer, I'm pretty sure I'm right where I want to be.
Truck alone:
Front: 32 5/8"_________Rear: 33"
Trailer hooked up with no bars:
Front: 33"____________Rear: 32 1/8"
Trailer hooked WITH bars:
Front: 32 5/8"_________Rear: 32 5/8"
So basically the weight of the trailer caused a 7/8" sag at the rear and a 3/8" rise at the front. After engaging the bars my rear came back up 1/2" (leaving a 3/8" sag) and the front came back to it's unloaded height. The trailer measures perfectly level when hitched up. Thoughts?
2012 Rockwood 2306
2007 Honda Ridgeline tow vehicle with Equal-i-zer and Prodigy P2
pg_rider is offline   Reply With Quote
Old 03-25-2012, 08:10 PM   #2
acadianbob's Avatar
Your measurements look good! But, I thought that Honda did not recommend use of a WD hitch on the Ridgeline?
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 03-25-2012, 08:18 PM   #3
Perfection.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-25-2012, 08:25 PM   #4
Triguy's Avatar
IIRC the info from Progressive, Equal-i-zer specs say the bars should be adjusted to eliminate at least 50% of the rise and the rear should be no higher than the loaded but unhitched height. So both are good.
How much of the rise does Honda specify should be eliminated? Different manufacturers have different recommendations.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-25-2012, 08:57 PM   #5
Triguy's Avatar
Another thought:
If you want to go the extra mile with checking their work, re-torque the L-Brackets to 65-75lbs, link plates to 50-70lbs.
Finally, make sure the link plates are flat against the frame.
Scott
2012 Shamrock 233S
Old 03-25-2012, 08:59 PM   #6
sherdep's Avatar
this was posted ona forum about the ridgeline
The manual states that they do not recommend a weight distributing hitch because "an improperly adjusted weight distributing hitch may reduce handling, stability and braking performance." If they actually need a weight distributing hitch, there is a good probability that they are also exceeding the recommended towing weight.
to the OP - your measurements look pretty good - I suspect that when the hitch was installed it was without any of your gear or water so you would have most likely had to adjust it again - in which this case you did and did a good job I might add
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-25-2012, 08:59 PM   #7
steeleshark2's Avatar
Perfect!!
steeleshark2 is offline   Reply With Quote
Old 03-25-2012, 09:02 PM   #8
sherdep's Avatar
Originally Posted by Triguy View Post
Another thought:
Thats a good idea
after a few trips with my equalizer I had to re-tighten the bolts -
I have also noticed after a few back ups at a weird angle the brackets have moved a little so am guessing I need to fix that before it becomes an issue.
to the OP - I suggest getting Max Air II Vents for the air vents so you can keep them open when it rains - you'll be glad u did - my 2306 has them and I keep the vents open all the time without issue
Old 03-25-2012, 09:09 PM   #9
Newbie
pg_rider's Avatar
They don't, but as sherdep quoted it's likely a CYA statement due to the "chance of misadjusting the hitch and causing handling problems". Of course, there's no mention of the benefits to using a PROPERLY ADJUSTED hitch. Lawyers -- grrrrrrrrr....
2012 Rockwood 2306
Old 03-25-2012, 09:10 PM   #10
Newbie
pg_rider's Avatar
Honda makes no mention of recommended sag / rise adjustments...
2012 Rockwood 2306
Old 03-25-2012, 09:13 PM   #11
Newbie
pg_rider's Avatar
Another thought:
Good point -- I forgot to put a wrench on all the bolts.
Funny you mention the link plates being flat -- one of them is slightly bowed, likely from the technician overtightening the bolts.
2012 Rockwood 2306
Old 03-25-2012, 09:16 PM   #12
Newbie
pg_rider's Avatar
Actually I didn't adjust it all, but I DO have more stuff in the front of the trailer now than when the hitch was installed. When it was installed, it appeared that it was distributing too much weight to the front of the truck. Now, with the additional weight in the trailer from me loading stuff into it, it appears to be right on. I consider myself lucky, cuz I really didn't want to start playing with washers and plate height adjustments.
2012 Rockwood 2306
Old 03-25-2012, 09:19 PM   #13
Newbie
pg_rider's Avatar
Thats a good idea
Guess what I did for two hours today -- installed two Camping World brand vent covers! For $20 each I couldn't resist.
Bit of a snag installing one over the Fantastic Vent in my bathroom. The holes for mounting the vent cover brackets to the vent surround weren't accessible from the roof of the trailer. So, I had to drop the fan down from inside the bathroom in order to gain access to the hole locations. Once that was done the rest of the job was a cinch. How did you install your cover over your bathroom vent?
2012 Rockwood 2306
Old 03-25-2012, 09:26 PM   #14
sherdep's Avatar
the Max Air's have a latch that allows you to flip them up to get access to install and be able to clean inside of them as well
When I purchased my trailer I paid the $75 a vent to just have the dealer install them so if anything ever happened to them they would warranty them
Old 03-25-2012, 09:53 PM   #15
Newbie
pg_rider's Avatar
I considered the benefits of the hinged mount on the MaxxAir, but honestly the basic vent cover comes off in literally one minute -- four easy nuts is all it takes. Definitely worth saving the ~$30 per cover for me...
I wonder if your dealer had to take a similar approach I did, with lowering the fan to access the vent surround. I'll take some pics next time I'm in my trailer so folks can see what I mean.
2012 Rockwood 2306
Old 03-25-2012, 10:04 PM   #16
sherdep's Avatar
I am unsure if they did or not cause they were installed when I took delivery. Seems straight forward of an install though.
Did you go with a Fan in front as well?
I have the fan in the bathroom and the standard vent in front
Old 03-26-2012, 09:10 AM   #17
Newbie
pg_rider's Avatar
No, I put a basic cover over the fan vent in the bathroom. I'd read that many people have used a basic cover (vs one made for fans) and still get good airflow. Seemed pretty good to me when I checked mine...
2012 Rockwood 2306
equal-i-zer
