Old 01-13-2011, 06:32 AM   #1
Big Dawg's Avatar
What do you tow with?
I have been reading various post about this section, but wanted to get an idea of what everyone uses as a tow vehicle compared with the camper. I just purchased a Gray Wolf 28BH, and I have a Chevy Avalanche which can tow 7,300 pounds. The dry weight on the Gray Wolf is 5,296.
Big Dawg is offline   Reply With Quote
Old 01-13-2011, 06:44 AM   #2
Herk7769's Avatar
Most members put their RV information in their signature block. This is highly encouraged so that we might be more helpful. The answer given by a MH guy might be totally unhelpful to someone in a 5th wheel.
If you are asking for an opinion on your combination, you should search this topic. I am sure you can spend many restful hours reading posts on why you made a great choice or a poor one.
They are both here in spades!
A place to start is : Travel Trailer Weight Calculator
HAM CALLSIGN - KC3FFW
Old 01-13-2011, 06:56 AM   #3
Head Rambler
A Common Rail Cummins wrapped in a Ram. Towing about 6k#.
But as Lou said, there's every combination and every reason why they're good and why they're bad.
Gotta go campin!
Old 01-13-2011, 07:16 AM   #4
Wanna Be Camper
SaskCampers's Avatar
Dodge Ram 2500 Megacab 4x4 with a hemi pulling an 8500lb 34' TT.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 01-13-2011, 07:32 AM   #5
Dawg, I see you are a new member, so I guess I will cut you some slack.
Dry weights are totally meaningless when it comes to towing. That 5200#Grey Wolf can climb to 7000 pounds in a real hurry. Besides the "dry" weight is a guestimate based on some genius engineers wet dream. Load it up and go to the scales. That is the only weight that is important.
BTW Dodge Cummins dually pulling a 13,350 fiver.
Old 01-13-2011, 10:15 AM   #6
Big Dawg's Avatar
Thanks gang, it seems like there are a ton of opinions on what is right. I guess it comes down to weighing it on some scales and seeing where you are at.
Old 01-13-2011, 10:52 AM   #7
My 5.3 L Chevy van with 3.73's tows @12K (GCWR) pretty good . Not sure I would want to go much heaver then that. I think we have about the same powertrain. I think that trailer will be around the max loaded.
2007Rockwood2601 is offline   Reply With Quote
Old 01-13-2011, 12:35 PM   #8
camping
tentcamper1's Avatar
Chevy crew cab 2500HD gas towing about 7800# to 8000#
FYI the weight sticker from the factory on my trailer was 7180#.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 01-13-2011, 03:22 PM   #9
M109Rrider's Avatar
Best guess is the Crusader weights between 10-12k fully loaded. I tow with a 05 4x4 Quadcab short bed 2500 Dodge Ram with a Cummins.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 01-13-2011, 03:34 PM   #10
bikendan's Avatar
BigDawg, i own an '07 Avalanche with the 5.3 and a 3.73 rear end.
my tow max is 7200lbs., which is only carrying a 150lb. driver. anything else, in the Avy, reduces that tow max number.
your 28BH has a GVWR of 7681lbs., meaning that's the most it can weigh.
Forest Rivers shows the fictional "dry" weight as 5339lbs.
you can add 400-500lbs. to get a ballpark weight from the factory. this is for the weight of normal options, that aren't included in the dry weight number.
which means before water, propane, battery and cargo, your 28BH will weigh around 5800lbs.
the 28BH's GVWR is nearly 400lbs. over your tow max with only a 150lb. driver.
i tow a 23' Hybrid that weighs a little over 5000lbs. loaded for camping.
since i live out west, i have lots of mountains to get over so i wouldn't tow anything heavier than what i have.
IMHO, with that GVWR and 31' long, i think you'll be looking for a 3/4 ton TV soon.
