04-07-2016, 06:05 AM
#101
My neighbor has a 2014 Duramax/Allison setup pulling a 12.5k 5th wheel. I've ridden with him up the same 6% grade (5-6 miles worth). My setup (7500 with a half ton gasser) has an easier time pulling that grade at the same rpm's. I can jump into the passing lane and leave him behind easily. It's not apples to apples, but does tell me that a matched setup is a matched setup.
Having 90% of available torque between 1700-4000 rpm and turbos with very little loss at elevation makes a great towing engine. Doesn't matter if that's accomplished burning diesel or gas.
No disrespect for diesels. They are the preferred engine. But some of these comments are ridiculous in the scope of what the OP is towing.
If I wanted to spend the money, I'd go diesel too. But don't think it's the only option for a relaxed towing experience. On rolling hills, my cruise is set, no downshifts, less than 2k rpms, and I'm talking with the family while my knuckles are nice and pink. The OP has many options that would do the same for him and not be a diesel.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
04-07-2016, 06:20 AM
#102
As a vehicle ages (miles), it will loose power. Just traded a 2010 (122k miles) for a 2016. It was starting to downshift on small hills even without the trailer. All my vehicles have done this as they age.
NEW truck!
04-07-2016, 06:46 AM
#103
Originally Posted by Jonol
I had a similar experience one time, the pedal to the floor clyming a hill and I found out that my v8 5.7 had a bad sparkplug and my engine was running on 7 cylinder insted of 8 !!
Could not tel mutch difference on flat road.
We had the same issue thing our 97 Silverado. But it was another issue causing the plug fouling. That's led to research and the purchase of a 05 Silverado with the 5.3 and pleased with it....and it pulls the same hill mentioned just fine.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
04-07-2016, 07:04 AM
#104
By now, DW and DH are probably starting get some direction. Any of the big 3 have a lot to offer. Don't try to compare your 2005 Silverado to any new truck.
There was a tremendous difference between our '08 Sierra and '13 Silverado. The new trucks have 4-wheel disc brakes, more speeds in the trans making for much better towing, fuel management for economy, different suspension, stiffer chassis, back up cameras, more comfort, more quiet, optional integrated brake controller (recommended), OnStar type features, and more.
Ford has an all aluminum body and EcoBoost that owners rave about, Dodge has come a long way since the 2002 we once owned. The new Silverado or Sierra has some aluminum components and would do the job-you would be comparing apples with oranges between the 2005 and the new ones.
Your in the driver's seat. Certainly, your choice will be a good one. Enjoy and happy campin'!!
04-07-2016, 07:26 AM
#105
That's why I went diesel a few years back. Not enough motor/ torque for the inclines. Got tired of all the shifting and searching for the right gear while going up hill and that was with a hemi. Since going cummins hills/ inclines are no longer a challenge. You could buy the perfect match, trailer weight to gas truck engine and maybe make your way up the inclines or you could buy a diesel and never worry about. I'm not saying I pull up steep grades at 80mph, but I am saying I can find a comfortable speed and climb without the engine racing or the tranny searching for gears. As long as I pull a trailer, it will be a diesel pulling it.
04-07-2016, 08:02 AM
#106
One of my trips to Yellowstone I drove a Silverado with a gas engine pulling a 24 foot Coachmen Catalina. Going west from Billings, I had the pedal to the metal just to maintain 45 mph. My next truck was a Silverado diesel and on the same route l just set the cruise at 60 mph and let it go. I am on my third Chevy diesel now. I have never smelled any diesel fumes from any of them. I have towed through the Rockys and to Alaska with no problems. I would buy another diesel even if I were not towing.
04-07-2016, 08:48 AM
#107
It would be suggested to post the years of trucks we are comparing. The OP has a 2005.There is a tremendous difference in features and performance from 2005 to 2016, gas or diesel no matter the brand.
Diesel and gas will always be argued. We were stopped in traffic along side a 2016 Silverado 2500 Duramax yesterday. I rolled down the window and DW asked why. I said I was curious about the smell and sound of the diesel when it started out. The Duramax diesel odor was very faint and it was very quiet on acceleration. I was envious, but I will probably never need one. The '13 Silverado 5.3L 6-speed is doing its job in style.
04-07-2016, 02:22 PM
#108
It's not just the diesel that helps, but also the turbo that typically comes with it, right? Naturally aspirated (non-forced) engines will lose effectiveness (not the right term, power?) as elevation increases above sea level. A forced-induction engine is effectively negating that effect (or at least minimizing it).
If hubby demands to stick to gas engines, and you expect to continue headed into significant grades, you should seriously consider a Ford F150 with the 3.5L Ecoboost (turbo). That's what those last 2 folks were referring to as there "little 6".
Another thing:
What transmission in the Chevy. Newer trucks have 6, 8, or 9 speeds. If yours is 5, it will hunt. If it's only 4, God help you.
04-07-2016, 02:29 PM
#109
Originally Posted by tragusa3
Yep. My little 6cyl gasser is towing 7500lbs and holds the speed limit on extended 6% grades while not going over 2500rpm.
X 2. A fully configured F150 like this has no problem in these conditions. No need to go to a 3/4 ton and or a diesel configuration. Just came back this week going through the appalachians to over 3,000 ft+ and was in the right hand lane all the time at 60 mph and sailed past the the average tractor trailer with about an 8500 LB load. Did the same twice across the Rockies and aon a regular basis twice a year through the Appalachians.
04-07-2016, 03:38 PM
#110
I agree with this comment and the others who have mentioned turbo engines vs. naturally-aspirated engines at altitude. My driveway is at 5,600-feet above sea level, so I have to drive "at altitude" when I go to the neighborhood grocery store. I've lived in Colorado over 50 years and had nearly 40 different cars and trucks and none drive or pull as well in the mountains as the turbocharged ones.
The reason is that every naturally aspirated engine loses approximately 3% of its rated (sea-level) horsepower per 1,000-feet of altitude gain. In other words, any non-turbo gas or diesel engine will lose 30% of its rated power crossing a 10,000-foot pass across the Continental Divide in Colorado. That's why WWII piston-engine airplanes that could climb to 30,000 feet had to have superchargers. And why Sir Charles had to gulp oxygen on the bench when he played against the Denver Nuggets!
The reason new trucks with modern diesel engines or the Ford Ecoboost can tow so well in the mountains is not because of the size of their engines, but because they are all turbocharged. After all, the Ecoboost is 3.5L and my Cummins is 6.7L, but both are turbocharged and both do well with their max loads in the mountains.
So, if the OP wants to comfortably tow that travel trailer through the Rocky Mountain West, I'd advise an engine--any engine, gas or diesel--with a turbo.
"Retirement is the best job I ever had!"
2020 Winnebago Navion 24V Sprinter Class C
Sold in 2021: 2016 Rockwood Signature Ultra Lite 8244WS 5th Wheel
Sold in 2014: 2012 Rockwood Mini Lite 2109S
04-07-2016, 04:01 PM
#111
All this talk just makes me wanna trade in my 2016 F-250 Gas SRW for a 2017 F-350 TurboDiesel DRW.
Could be a very expensive thread
But then I'm just very easily tempted by new toys
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
04-07-2016, 05:06 PM
#112
Originally Posted by ApexBunk
My husband can't stand the smell of diesel (he's an ASE Master tech,too!) with some of the gas vehicles towing 8k-9k lbs, I have to think there are other options.
Our tow capacity is around 8500 #. What good is a tow capacity if you can't even tow less than that?
My truck most of the time ill not even downshift but on the 6-7% grades it usually will drop out of overdrive and just hold whatever speed I have on the cruise control.
The new diesels do not smell like diesel at all unless you spill it on yourself when filling up. They are clean and have really any exhaust smell.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
04-07-2016, 07:25 PM
#113
That's why the Ecoboost is such a great motor, it flies no matter if it's full or empty.
04-07-2016, 09:02 PM
#114
Originally Posted by schrederman
I've often wondered why I waited so long to buy the diesel that I have now. My trailer's not as heavy as yours and I'll never go back to towing with a gas engine. Inclines where I used to struggle with the truck in 3rd and revved up to 4400 rpm don't even rate a downshift. The diesel grunts a little louder and pulls up the hill. On the other side going down I hear the exhaust brake working and I'm still sitting at 65 mph, not heating and wearing the brakes on the truck or trailer. There are too many good things about the diesel towing experience to ignore... and I very seldom experience any diesel smell, certainly not while towing.
DITTO.
Doc
04-07-2016, 09:03 PM
#115
Without a doubt, it is a great motor. Ford needs to do a V8 ecoboost!!! LOL
Doc
04-07-2016, 09:14 PM
#116
Sorry, but if you think you can jump in the passing lane and leave a Duramax it's because he wants to "BOOST" your ego, even tho he's 5k heavier, my experience is he's still laughing at you on the inside!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
04-07-2016, 09:30 PM
#117
Maybe so, but he's a good guy that sounds genuine. I typed that for dramatic effect mostly...
I think there are lots of diesel owners with their nose in the air. When, in fact, they are not having the dramatically different experience that some think they are.
Sure, a half ton would be a dog with those weights and couldn't do it without breakdowns. But that's not what the OP is doing, and therefore the suggestions to 'go diesel or go home'. Sound like an 'Ego-boost' to me.
I stated my perspective from the experiences I've had. In the end, comparing to anything else is not important. If we are satisfied with what we're doing, then fine.
04-07-2016, 09:35 PM
#118
Done with this
Can't believe nobody has said it....It goes up the hill.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
04-07-2016, 09:53 PM
#119
Belaboring this point is going to look like it DOES matter (too much) to me. But I'd like to hear someone else's take on this logic.
Duramax 397hp and 765 torque
Ecoboost 365hp and 420 torque
Duramax pulling 12,500 and Ecoboost pulling 7500.
If my math is correct, the Ecoboost is pulling 60% of the weight with 55% of the torque and 92% of the horsepower.
In addition, it looks like his truck is roughly 1500 pounds heavier.
Is it that silly to expect these two towing experiences to be similar?
04-07-2016, 09:55 PM
#120
What does your truck do on steep inclines?
But at least the dirty max won't stretch the timing chain, while heading up the mountain.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
