Old 07-07-2016, 07:16 AM   #1
What gear do I put my tranny in
Hello all,
I just purchased a 2016 Fr3 ford v10. I don't tow with my Rv. My transmission has D, 4, 2, and 1. When I am going up hill, what gear should I put my transmission in. Also, what gear when I am going down hill. I also have a tow/hall button, please let
me know if I should use that. Yesterday, while going down hill in Shenandoah National Park, my transmission seemed to be revving very high, 3 to 4k rpm. Thank you
Nsopti is offline   Reply With Quote
Old 07-07-2016, 08:57 AM   #2
3-4K RPM on a steep downhill is normal, same for uphill and won't hurt anything. The engine is designed to run at those RPM's all day if needed. Look up engine braking as the reason for high downhill RPM's. It is not burning gas, but is saving your brakes.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 07-07-2016, 11:11 AM   #3
Thanks for the quick reply, so should I just leave the transmission in regular D. Should I at least turn off the overdrive, by pressing the tow haul button
Old 07-07-2016, 12:38 PM   #4
Yes, regular D. I would use the tow/haul button. Don't think it turns off overdrive. Nothing wrong with using overdrive. The computer will downshift if it needs to. Some people don't like tow/haul because they say it downshifts too aggressively on steep downhills. But remember that the engine and transmission are designed to do that. Read your owners manual about tow/haul mode.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Old 07-07-2016, 12:46 PM   #5
ilmor's Avatar
If you're not towing or hauling you don't need to use tow/haul mode. Just put her in drive "D" and enjoy the ride!
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-07-2016, 01:59 PM   #6
I put my Silverado 3500 when pulling in tow/haul and cruise and exhaust brake on and most the time not pulling. It helps out with the braking. It's what I do
spock123 is offline   Reply With Quote
Old 07-08-2016, 01:11 PM   #7
It's a motorhome, so it is hauling itself.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Old 07-08-2016, 01:40 PM   #8
I disagree.
With the added weight of the motorhome body on that chassis, it would be very similar to a truck (using that chassis) towing something.
I'd be using the tow/haul mode in the hills and mountains for sure.
That is what it was designed for.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 07-08-2016, 03:56 PM   #9
Boondocking Only
ddbck's Avatar
Check out an SCT with custom tunes from 5 Star Tuning, it will turn your V10 into a hill pulling animal!
2014 Shamrock/Roo 21SSL
Complete LED Lighting
Off Road Package
2010 F250 Lariat 6.8 V-10 w/Timbren SES
Custom Tunes by 5 Star Tuning
Boondocking Only
ddbck is offline   Reply With Quote
Old 07-08-2016, 04:13 PM   #10
Tombsy's Avatar
Tow/haul gives you engine braking, when you tap the brake it will drop a gear. Thru the Rockies it worked amazingly well, I hardly had to use the brakes down hill at all. The motor likes to rev.
Brian
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
