Old 04-24-2014, 12:28 AM   #11
Originally Posted by OKI Marine View Post
Best place I found to purchase seals and bearings is R & P Carriages online. They are located in Illinois and list there products on ebay. NAPA carries bearing that fit rv's. You just give them the number on the bearing. Found that out from our RV Dealer. that is where they get them
I have been using amsoil for years and the red commercial stuff lasts a long time. I have taken wheel bearing a part and have found it is not to be needed yet. Use it on trailers ,tractors, motor home, anything it applies too. good stuff. Never had a failure..Pete
petey is offline   Reply With Quote
Old 04-24-2014, 07:15 AM   #12
MtnGuy's Avatar
I too use the Lucas Red and Tacky #2.
Old 04-25-2014, 08:36 AM   #13
Komodo's Avatar
Originally Posted by 05CrewDually View Post
What I would recommend is clean out all the old grease. Inspect the bearings and races. Repack the bearings with a High Temp./High Pressure Wheel bearing grease. Replace wheel seals.
There are grease bases that you are not suppose to mix, for this reason is why they list the type of grease used by the manufacturer. If you can't match the base, replace it with another high temp based grease.
Actually, all I need to do is pop off a rubber seal and pump new grease till the old grease is out.
I don’t know how long I must wait for a more complete bearings job.
This site is not Ultrulube but it works the same way.
E-Z Lube Trailer Axles
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. Wolfgang Riebe
Komodo is offline   Reply With Quote
Old 04-25-2014, 08:41 AM   #14
Komodo's Avatar
Originally Posted by cobiker View Post
Also have the AL-KO Ultralube hubs and using Royal Purple NLGI No. 2 Synthetic Ultra Performance grease. Purchased thru Amazon last year.
Here's the spec sheet.
http://www.royalpurpleconsumer.com/w...ads/PS_UPG.pdf
First time to perform bearing maintenance, so wondering what sources you use for your Grease Seals and bearings if needed?
I found this post interesting; note the pdf files at the bottom.
Ultra-Lube Axles and Bearings Procedures
Old 04-25-2014, 08:48 AM   #15
PhoneDude 8289's Avatar
After finding one of the grease seals leaking I cleaned out all the old grease from the spindles, hubs and bearings. Replaced all the seals and went back with Lucas Red And Tacky #2. This is on a four month old unit
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 04-25-2014, 08:48 AM   #16
Brother Les's Avatar
With the grease-able bearings, you should not have to worry about 'a more complete bearings job'...... pump a little in about twice a year and clean off the excess. It will be fine. Some people may take everything apart themselves and not get the tension put back correctly and your bearing may then burn out.
Brother Les
Old 04-25-2014, 09:30 AM   #17
jevanb's Avatar
I use aeroshell #5
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 04-27-2014, 03:16 PM   #18
Last week after finding one of my wheel seals was leaking I went to a shop that deals only in trailer axles for some new seals. He made a couple of comments that I wasn't aware of.
1. E-Z lube axles are handy but there isn't any way of knowing just how much grease is truely in the hub. In almost all failures that he has seen, there is too much grease, causing the seal to fail.
2. Seals are only to keep dirt out... not grease in.
3. Always test the seal on the actual spindle before putting it in the hub. It can happen where a trailer will have two different size spindles and you would never know it. His mechanics always test them. Same will apply with the bearings.
4. He never sells just brake shoes. Chances are, if the shoes are wore out, one or more components of the assembly are near their useful life (springs, magnet, clips, wires) and could cause a failure. Not only that, it's an easy job to replace the backing plate with all components attached.
After talking to him, I went home and cleaned out all the old grease, hand packed the bearings with Mobil 1 synthetic wheel bearing grease, assembled the hubs and swore to never use the EZ lube again.
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
1Texan is offline   Reply With Quote
Old 04-27-2014, 07:55 PM   #19
Toy-aholic
Funny, I've been an auto tech for 36+ yrs and the only bearing failures I've seen was from LACK OF grease and I literally pour the bearings as dust out of the hub. Never heard of too much grease causing a failure...live & learn.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 04-27-2014, 11:27 PM   #20
moondog2000's Avatar
When I bought my X-Lite with ez lube axles the only answer I could get as to what type of grease to use was what the rv dealer would pump in was grease from Napa.I could see the grease was green so I bought some Lucas X-Tra heavy duty grease. It had the specs I needed . I hate mixing greases for the fear of them being Incompatable and a lot of my towing is to the Grand Canyon in the summer where temps can run 115 out in the desert. Normaly I would tore down the hubs, cleaned them and repacked them. But the trailer was brand new so I jacked each wheel up and spun it pumping lucas in till I got fresh grease coming out the front of the hub. I have towed it for a year now with no problems and before I go to the GC this June I will repeat the process . I wil check each hub for play in the bearings. I believe this is the same as packing your bearings in a regular axle and you should not have to touch them for a year or better.
05 Silverado Z71 4X4
2013 Forest River X-LITE
Days camped in 2018, 27
moondog2000 is offline   Reply With Quote
