04-22-2014, 08:02 PM
What grease is best for repacking
I have a AL-KO Ultrulube. It says that I need to use NLGI Grade 2 lithium complex, grease with a minimum dropping point of 400F for the repack.
http://dutchmen.com/image/data/docum...kobrochure.pdf
The only grease I can find in our local shops that indicate dropping temperature is Quaker State Multi-Purpose Grease and Wheel Bearing Lubricant. It has a 525F dropping point, but it does not say "Lithium complex"
The other choice I have is Mystik Hi Temperature Grease, it has "Lithium complex" but does not say what is the dropping point.
Does anyone know if one of these products will work?
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. Wolfgang Riebe
04-22-2014, 08:14 PM
Someone will answer this and I'll be interested in the answer also.
Sent from my XT907 using Forest River Forums mobile app
2018 Forester 3011 DS
04-22-2014, 08:44 PM
2007 WildCat 32QBBS
What I would recommend is clean out all the old grease. Inspect the bearings and races. Repack the bearings with a High Temp./High Pressure Wheel bearing grease. Replace wheel seals.
There are grease bases that you are not suppose to mix, for this reason is why they list the type of grease used by the manufacturer. If you can't match the base, replace it with another high temp based grease.
04-22-2014, 10:36 PM
PT Avenger 33BHS-TE
2020 f-250
04-23-2014, 12:44 AM
been using pennzoil 707L red grease for a few years now. worked well for me so far. NLGI-2 lithium base
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
04-23-2014, 02:16 AM
Just a member
Yes they will but I would recommend you make a trip to your local Crappy Tire and pick up some Lucas Red "N" Tacky #2. It has (for moi) outperformed a variety of other No 2 grease products designated for applications such as this.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
04-23-2014, 02:43 AM
H2oski
If you are removing, cleaning, inspecting, hand repacking and reinstalling I would use the Lucas Red N Tacky #2.
That's what I do. Good luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
04-23-2014, 11:21 PM
Also have the AL-KO Ultralube hubs and using Royal Purple NLGI No. 2 Synthetic Ultra Performance grease. Purchased thru Amazon last year.
Here's the spec sheet.
http://www.royalpurpleconsumer.com/w...ads/PS_UPG.pdf
First time to perform bearing maintenance, so wondering what sources you use for your Grease Seals and bearings if needed?
2015 Keystone Raptor 425TS full body paint
TV 2015 RAM 3500 MC 4x4 DRW w/ AC69RC HD Trans
Pullrite Superglide 2300 24k w/ OE adapter 25k
04-23-2014, 11:42 PM
I just repacked mine last week and used the Lucas Red n tacky #2. It has a drop temp of 540. I would make sure you clean out the old grease and not mix the two if you switch from what you already have.
04-23-2014, 11:48 PM
Best place I found to purchase seals and bearings is R & P Carriages online. They are located in Illinois and list there products on ebay. NAPA carries bearing that fit rv's. You just give them the number on the bearing. Found that out from our RV Dealer. that is where they get them
04-24-2014, 12:28 AM
I have been using amsoil for years and the red commercial stuff lasts a long time. I have taken wheel bearing a part and have found it is not to be needed yet. Use it on trailers ,tractors, motor home, anything it applies too. good stuff. Never had a failure..Pete
04-24-2014, 07:15 AM
I too use the Lucas Red and Tacky #2.
04-25-2014, 08:36 AM
Actually, all I need to do is pop off a rubber seal and pump new grease till the old grease is out.
I don’t know how long I must wait for a more complete bearings job.
This site is not Ultrulube but it works the same way.
E-Z Lube Trailer Axles
04-25-2014, 08:41 AM
I found this post interesting; note the pdf files at the bottom.
http://www.forestriverforums.com/for...ures-9666.html
04-25-2014, 08:48 AM
After finding one of the grease seals leaking I cleaned out all the old grease from the spindles, hubs and bearings. Replaced all the seals and went back with Lucas Red And Tacky #2. This is on a four month old unit
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
With the grease-able bearings, you should not have to worry about 'a more complete bearings job'...... pump a little in about twice a year and clean off the excess. It will be fine. Some people may take everything apart themselves and not get the tension put back correctly and your bearing may then burn out.
Brother Les
04-25-2014, 09:30 AM
I use aeroshell #5
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
04-27-2014, 03:16 PM
Last week after finding one of my wheel seals was leaking I went to a shop that deals only in trailer axles for some new seals. He made a couple of comments that I wasn't aware of.
1. E-Z lube axles are handy but there isn't any way of knowing just how much grease is truely in the hub. In almost all failures that he has seen, there is too much grease, causing the seal to fail.
2. Seals are only to keep dirt out... not grease in.
3. Always test the seal on the actual spindle before putting it in the hub. It can happen where a trailer will have two different size spindles and you would never know it. His mechanics always test them. Same will apply with the bearings.
4. He never sells just brake shoes. Chances are, if the shoes are wore out, one or more components of the assembly are near their useful life (springs, magnet, clips, wires) and could cause a failure. Not only that, it's an easy job to replace the backing plate with all components attached.
After talking to him, I went home and cleaned out all the old grease, hand packed the bearings with Mobil 1 synthetic wheel bearing grease, assembled the hubs and swore to never use the EZ lube again.
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
04-27-2014, 07:55 PM
Toy-aholic
Funny, I've been an auto tech for 36+ yrs and the only bearing failures I've seen was from LACK OF grease and I literally pour the bearings as dust out of the hub. Never heard of too much grease causing a failure...live & learn.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
04-27-2014, 11:27 PM
When I bought my X-Lite with ez lube axles the only answer I could get as to what type of grease to use was what the rv dealer would pump in was grease from Napa.I could see the grease was green so I bought some Lucas X-Tra heavy duty grease. It had the specs I needed . I hate mixing greases for the fear of them being Incompatable and a lot of my towing is to the Grand Canyon in the summer where temps can run 115 out in the desert. Normaly I would tore down the hubs, cleaned them and repacked them. But the trailer was brand new so I jacked each wheel up and spun it pumping lucas in till I got fresh grease coming out the front of the hub. I have towed it for a year now with no problems and before I go to the GC this June I will repeat the process . I wil check each hub for play in the bearings. I believe this is the same as packing your bearings in a regular axle and you should not have to touch them for a year or better.
05 Silverado Z71 4X4
2013 Forest River X-LITE
Days camped in 2018, 27
