Old 05-18-2015, 03:41 PM   #41
Fulltime family RVer
For me, with the campers we were looking at and my inexperience level- I felt like I needed a dually and diesel. It's the only truck I've owned and I'm happy with it.
Originally Posted by Oakman View Post
3. With a diesel I can fuel up at the truck pumps and not have to worry about maneuvering room or whether the canopy over the pumps is high enough to fit under. BTW, thats reason enough for having a diesel.
This is more awesome than Oakman even begins to describe. Fueling up at truck stops is so simple.
Old 05-18-2015, 03:42 PM   #42
BamaBob's Avatar
Originally Posted by doc73 View Post
I have not heard many address the maintenance increases. I do my own oil so other than being 4 gallons (LOL) instead of 6qts is fine... Do you need to replace your fuel filters every 10,000 and so on? I am used to the oil every 5,000 to 10,000 and KN air filter cleaning once every 30,000.
With the diesel I know DEF comes into play, does the vehicle get some good distance on 2.5 gallons of DEF or is it best to keep a few gallons in the rig?
We have been researching diesel as well Doc. The RAM 3500 we are considering gets 15K between Oil Changes and has a 8 GAL DEF Tank. Depending on where we are going (we want to do the AlCan in '18) I certainly would have a spare 2 GAL DEF Can in the toolbox
I have heard that a full DEF tank (in the above truck) gets 10K Miles but towing factors, idling and so forth come into play to reduce that. Also the Cummings can use Biodiesel which supposedly refuses DEF consumption (and gives you better mileage)
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-18-2015, 03:45 PM   #43
Oakman's Avatar
BTW, my 6.4 liter diesel develops peak torque (650 lb-ft) at 2000 RPMs and peak horsepower (350 hp) at 3000 RPMs.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-18-2015, 03:45 PM   #44
I believe that chart is a comparison of a GAS V8 vs. the Ecoboost.
It is, but the numbers and curve directly dispute the statement made about gas torque curves. I would surmise again that maybe the myth is related to a normally aspirated engine, but it is perceived by many to mean gas engines. It certainly does not apply to all gas engines as the chart displays.
madmaxmutt is offline   Reply With Quote
Old 05-18-2015, 03:46 PM   #45
Here's the real question why a 3/4 ton when the only difference between that and a 1 ton is one leaf spring and about $600
broncodriver is offline   Reply With Quote
Old 05-18-2015, 03:56 PM   #46
You can also fill the DEF tank at the truck stop for under $3 a gallon VS 3 times that price from a auto parts store.
Love our new F350 and the 440HP and 860 ft of torque not an issue to get up to speed before the end on an on ramp and comes in handy for passing as we're 70 long with the boat behind.
Old 05-18-2015, 04:02 PM   #47
Who Dares, Wins
doc73's Avatar
But my guess is his point is it is showing the high torque at lower RPM. I do know the EB is impressive but I am not going to do a f150 or 1500, definitely a 2500. But this is good info for the next person that might find this thread. Thanks you for the info.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 05-18-2015, 04:17 PM   #48
Who Dares, Wins
doc73's Avatar
Nothing more than the fact that 2500 are a dime a dozen around here for all the amish builders. 3500 are less common unless in the work truck. It is $60 more for reg but that is what it is. If I found the perfect 3500 then I would buy it but again, 2500's are more common.
2015 ChevyHD D-Max
Old 05-18-2015, 04:20 PM   #49
Who Dares, Wins
doc73's Avatar
I had heard that the Pilot Flying J's (and I am sure other truck stops) had this. Guess it is just another pump at the fuel pump? I would do this just to save the cash for normal cruising if they started doing this at the regular gas stations.
2015 ChevyHD D-Max
Old 05-18-2015, 04:23 PM   #50
I think many truck stops have these pumps. I don't use it, but I've noticed it pretty often.
Otherwise, they sell it by the gallon inside.
diesel, gas
