Old 05-18-2015, 07:28 PM   #81
Iwannacamp's Avatar
Originally Posted by doc73 View Post
Interesting. So then a dry filter would be OK then? Just not the oiled?
They have bigger holes...that's why they work. They let the pine knots and rocks in...just the talcum powder dirt...the worst kind.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 05-18-2015, 07:30 PM   #82
asquared's Avatar
I was told by my mechanic to never put a k&n filter in a diesel but I am unable to tell you why.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 05-18-2015, 07:30 PM   #83
Iwannacamp's Avatar
Sorry. Don't let them it...
2017 Puma 297RLSS
Old 05-18-2015, 07:36 PM   #84
My diesel came with a k&n filter . after awhile of having the truck the check engine light came on. Took it to the garage and they said the k&n filter was letting the engine suck to much air . Put a paper filter on and light went off.
Big Red and 30WR is offline   Reply With Quote
Old 05-18-2015, 07:51 PM   #85
wlhpas's Avatar
Send a message via AIM to wlhpas
I had the same consideration a month ago. After having 3 diesels I thought I'd like to try gas because of the option cost, fuel difference, and routine maintenance cost. After much research and only towing a Crusader 290rlt loaded, I stayed with the diesel. Towing is 11+ with diesel and gas would have been 6-. Towing capacity rating was barely enough with gas while diesel gave me over 4000 lb. cushion. I dropped from a Ram 3500 dually to Ford F250. Just more convent without dials.
Days camped 2012 - 73; 2013 - 58; 2014 - 41
Days camped 2015 - 17
Bill and Pamela Hancy
TV: 2015 Ford F-250
RV: 2013 Crusader 290RLT
wlhpas is offline   Reply With Quote
Old 05-18-2015, 07:52 PM   #86
jevanb's Avatar
K&n oiled filters destroy the MAP sensor. That is why you don't use them
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-18-2015, 07:57 PM   #87
mike.t's Avatar
Doc. They say if you are going to change stay with a dry pleated one.
Side note. I have a banks CAI for a 2011/12 Duramax $125.00 Plus shipping. California based.
2013 Ram 1500 4X4 Hemi
2018 Wilderness 2450FB
1998 Jeep Wrangler
2014 Dodge Durango
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-18-2015, 08:03 PM   #88
jevanb's Avatar
Originally Posted by mike.t View Post
Doc they say they dust an diesel engine because the engine pulls so much air it pulls some oil. They are great for gasser's.
From an earlier post in irv2
http://www.irv2.com/forums/f123/dete...-115270-2.html
Look on page one of this and #3
That is true but the oil gets in the MAP and it can't read correctly. Oil in its self is a great collector of crap. That is why every dmax owner should reroute their PVC as that crap is sucked into their turbo horn.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 05-18-2015, 08:17 PM   #89
William
WEMig's Avatar
Originally Posted by Harkerr View Post
Diesels make their torque at lower rpm. Much better for towing and better milage. No contest.
Initial cost? Fuel mileage while towing? Resale after 10 years? There is a contest. Depends on the needs of the owner. This coming from someone that has also owned diesels.
WEMig is offline   Reply With Quote
Old 05-18-2015, 08:32 PM   #90
As a side note, I went fro 6mpg to 13mpg. As far as maintenance cost, not real sure, my new truck is covered for two years with all fluids so.....
rarterbury is offline   Reply With Quote
diesel, gas
