10-27-2015, 07:48 AM
What hitch are you-------------------
I'm about to purchase a F-250 TV with a 6'8" bed. My question is what type of hitch for a fifth wheel are you using to tow a 2011 Rockwood fifth wheel? The fifth wheel
has pretty much square corners.
I am presently using a "SLIDER #3100" which weighs 400#. I would like to go to a different hitch that will prevent the fifth wheel from hitting the cab of the F-250 with a 6'8" bed.
Any suggestions well accepted.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
10-27-2015, 08:21 AM
I have a 2013 F-350 with the 6' 8" bed. My truck has the factory tow package with the under bed 5th wheel mounts. I use the Demco Hijacker that is designed to be used with the Ford system. I love it. It is an auto-slide system and I never have to worry about it. It is a bit heave, however I put a eye bolt I the ceiling of my garage and bought a chain hoist from harbor freight that I use to lift the hitch in and out of the truck.
10-29-2015, 06:05 AM
Once again asking for suggestions!
Need more input on the type of hitch being used on 6'8" beds for
fifth wheel towing. I have a Rockwood 8285 WS fifth wheel. I'm pretty sure
I will need some type of slider hitch to keep the front cap from hitting the truck cab.
My front cap is pretty much square across the front. It is a 2011/12 year
model. I have enclosed a picture of the front of my fifth wheel for some comparison to help in getting suggestions. I am using a #3100 Pul-Rite
slider hitch now. It is too heavy to remove from bed once installed.
I need input on a lighter hitch for my 6'8" bed so it can be removed when not towing.
2019 WILDCAT 28 SGX
10-29-2015, 06:25 AM
Sid why not leave it hooked to the Pin? Cover it and No Lifting! Youroo!! :
10-29-2015, 06:43 AM
If you want to go with a lighter hitch what I would do is switch to a standard 5th wheel hitch in the truck and put a Reese Revolution pin box on you 5er. What then happens is that the trailer will pivot on the pin box rather than on the trailer hitch. It sounds very odd and you would think that it would not work, but it actually should give you the clearance you need.
10-29-2015, 07:27 AM
It would move the pivot point back 17" - 20"
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
10-29-2015, 12:16 PM
Left Coast
Pull-right Super glide weighs in at just under 200lbs.
10-29-2015, 04:03 PM
No need for a slider with the Reese Sidewinder, check them out on E-Trailer
Joe & Beverly
2014 8289WS lifted
10-29-2015, 06:26 PM
Sid,
I have a 2010 Rockwood 8285WS. Pull it with an F150 with a 6 1/2' box, Reese 16K fifth wheel and the Reese Sidewinder. I never have a problem.
I am surprised you don't have the Sidewinder on your unit, I though that was standard.
Are you buying your truck at Palm Coast Ford?
2020 F250, 7.3 gas, 34 ft. Fifth Wheel, SOB
10-29-2015, 06:30 PM
The Reese 16K comes breaks down into two pieces so it's easy to move on and off he truck when necessary. Although I tend to leave mine in the truck.
10-29-2015, 06:31 PM
Left Coast
you'all know if the pin-box width is a standard, or different widths?
10-30-2015, 12:38 AM
I have the Demco Hijacker auto slide and love it.
10-30-2015, 08:32 AM
All same width
10-30-2015, 08:35 AM
2014 f350 with 20k curt fixed hitch (non slide) pulling Sierra 365 saq, no trouble not having a slider
10-31-2015, 07:24 PM
Anderson Ultimate fifthwheel hitch. Great to tow with and at 70lbs for the steel and 35lbs for aluminum it is unbeatable.
10-31-2015, 07:33 PM
Hello,I have a Super Glide that may be your answer and it's for sale
11-01-2015, 09:59 AM
Thanks to all
I would like to thank all that submitted suggestions for purchase of a new hitch for a F-250 use with a "Sidewinder" hitch..
2019 WILDCAT 28 SGX
11-01-2015, 12:30 PM
The hitch is a mod 3300 16k with rails and capture plate for Moryde pin bpx
11-06-2015, 11:54 AM
B&W Companion slider with an F250 short bed here...haven't actually used the slide feature with the fiver hooked up yet but it's an awesome hitch. I have slid it without the trailer and it moves very smoothly and automatically locks in the rear position after sliding. Weighs about 253# total-head assembly about 45#, the base weighs 208#. Also rated for 18k.
Dave & Amy
5 kids, 2 with 2 legs, 3 with 4 legs
2016 Columbus 385BH
2016 F350 6.7L PSD CC Lariat DRW
Ford factory puck system with 26.5k hitch
