Old 10-27-2015, 07:48 AM   #1
DAISY BOYKIN's Avatar
What hitch are you-------------------
I'm about to purchase a F-250 TV with a 6'8" bed. My question is what type of hitch for a fifth wheel are you using to tow a 2011 Rockwood fifth wheel? The fifth wheel
has pretty much square corners.
I am presently using a "SLIDER #3100" which weighs 400#. I would like to go to a different hitch that will prevent the fifth wheel from hitting the cab of the F-250 with a 6'8" bed.
Any suggestions well accepted.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
Old 10-27-2015, 08:21 AM   #2
I have a 2013 F-350 with the 6' 8" bed. My truck has the factory tow package with the under bed 5th wheel mounts. I use the Demco Hijacker that is designed to be used with the Ford system. I love it. It is an auto-slide system and I never have to worry about it. It is a bit heave, however I put a eye bolt I the ceiling of my garage and bought a chain hoist from harbor freight that I use to lift the hitch in and out of the truck.
Dinostop is offline   Reply With Quote
Old 10-29-2015, 06:05 AM   #3
Once again asking for suggestions!
Need more input on the type of hitch being used on 6'8" beds for
fifth wheel towing. I have a Rockwood 8285 WS fifth wheel. I'm pretty sure
I will need some type of slider hitch to keep the front cap from hitting the truck cab.
My front cap is pretty much square across the front. It is a 2011/12 year
model. I have enclosed a picture of the front of my fifth wheel for some comparison to help in getting suggestions. I am using a #3100 Pul-Rite
slider hitch now. It is too heavy to remove from bed once installed.
I need input on a lighter hitch for my 6'8" bed so it can be removed when not towing.
Name:	RALLY & VENT HOOD 002.JPG
Old 10-29-2015, 06:25 AM   #4
Sid why not leave it hooked to the Pin? Cover it and No Lifting! Youroo!! :
Old 10-29-2015, 06:43 AM   #5
If you want to go with a lighter hitch what I would do is switch to a standard 5th wheel hitch in the truck and put a Reese Revolution pin box on you 5er. What then happens is that the trailer will pivot on the pin box rather than on the trailer hitch. It sounds very odd and you would think that it would not work, but it actually should give you the clearance you need.
Old 10-29-2015, 07:27 AM   #6
PhoneDude 8289's Avatar
Smile
It would move the pivot point back 17" - 20"
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is online now   Reply With Quote
Old 10-29-2015, 12:16 PM   #7
Left Coast
Pull-right Super glide weighs in at just under 200lbs.
Old 10-29-2015, 04:03 PM   #8
No need for a slider with the Reese Sidewinder, check them out on E-Trailer
Joe & Beverly
2014 8289WS lifted
Old 10-29-2015, 06:26 PM   #9
Blaster 84's Avatar
Sid,
I have a 2010 Rockwood 8285WS. Pull it with an F150 with a 6 1/2' box, Reese 16K fifth wheel and the Reese Sidewinder. I never have a problem.
I am surprised you don't have the Sidewinder on your unit, I though that was standard.
Are you buying your truck at Palm Coast Ford?
2013 F150 XLT, SuperCab, Ecoboost; Rockwood 8285WS
Nights camped:
2014 - 57
2015 - 91
2016 - 171
2017 - 107
Blaster 84 is offline   Reply With Quote
Old 10-29-2015, 06:30 PM   #10
Blaster 84's Avatar
The Reese 16K comes breaks down into two pieces so it's easy to move on and off he truck when necessary. Although I tend to leave mine in the truck.
Nights camped:
2014 - 57
2015 - 91
2016 - 171
2017 - 107
hitch
