02-19-2019, 08:34 PM
What is a good WDH and Sway Hitch
New to RVing and we are going to pick up our new Wolf Pack 25Pack 12+ this Saturday. We have a 3/4 ton Ram diesel truck and need some help with picking out the correct WHD and Sway Hitch. Any help will be greatly appreciated. Thanks in advance!!!
02-19-2019, 08:41 PM
Who Dares, Wins
I had an equalizer 4 point hitch when we had a Travel Trailer. Worked great.
2015 Chevy HD D-Max
2022 Impression 315MB
02-19-2019, 09:07 PM
Multi-Slacker
Your choices are:
Propride
Hensley
Equalizer 4 point
Reese
Husky Centerline
Blue Ox
Andersen
I have used both the Andersen and the Husky Centerline and both are good hitches. The Hensley/Propride are by all accounts vastly superior to the others. There are some good youtube videos of each. Watch and pick the one your like best. Watch both hitch and unhitch vids and pick what you like and can afford.
You'll be stuck with what your dealer has if you want him to install this weekend.
Safe Travels
02-19-2019, 09:21 PM
Equalizer 4 point, make sure it is the Equalizer brand
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
02-19-2019, 10:31 PM
Another 4pt Equal-i-zer fan..
02-19-2019, 10:42 PM
I previously towed with a Hensley Arrow, and now have a Husky Centerline TS. The Hensley performed as advertised; it eliminates all trailer sway. With the Husky, I have felt an occasional jiggle in a wind gust followed by an immediate correction. Both hitches provide a safe, relaxed towing experience with no trailer sway.
When it comes to weight distribution, the Husky performs better than the Hensley. I've found it more effective with a greater range of adjustment for equalizing weight to the tow vehicle’s front axle.
The Husky Centerline TS is a 4-point anti-sway system, as are the Equalizer and Reese Steadi-Flex. These hitches control sway through tension in the hitch head, combined with the friction of trunnion bars on sway control brackets. There are lots of satisfied Equalizer owners on this forum. I can recommend the Husky 4-point system as well.
2017 Cherokee Grey Wolf 25RL
2017 Nissan Titan 4x4
02-19-2019, 11:04 PM
Broken Toe
I got the reese dual-cam and am very happy with it. 90% of the performance of the Propride, 30% of the cost.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Why do you want a WDH with a 3/4 ton TV And a 25 ft TT?
Edit: Not sure why they call it a 25 and make you do math when it’s 37 feet - very odd IMHO. Anywhooo...you definitely need WDH and anti-sway. Lots of good choices ITT.
TV - 2020 RAM 3500 Mega Cab SRW with 6.7 Cummins HO & Aisin 6 spd, 4k payload, 23k towing
2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Great bourbon-just about any of San Diego’s craft beer
02-19-2019, 11:19 PM
I agree with CurtP's post. Propride and Hensley are based on the same sway elimination design. With one, the trailer cannot sway as commonly described. They are significantly more expensive than any other hitch. Both can periodically be obtained used at reduced cost by folks moving to 5th wheel trailers.
The remainder are sway control hitches. Using some form of friction, they absorb and dissipate sway energy.
If you search this or other RV sites, I doubt you will find posters asking for help with a setup that is experiencing sway with a Propride or Hensley hitch. You will find this type of post for the others.
It is my observation that, if you do have sway issues with sway using the other hitches, you will get recommendations to adjust and manage your trailer's tongue weight and the tension on the WD bars, then a potentially expensive list of modifications to make on your TV that may come close to eliminating the cost differential between a Propride or Hensley hitch and the others.
Bottom line, none are "bad" hitches. Each has pluses and minuses. You need to decide which pluses are important to you and which minuses you can live with.
As Curt noted, do some more searching and reading. Only you can decided what is the "best" hitch for your situation.
I have a Propride and am completely satisfied with it's performance.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
02-19-2019, 11:26 PM
IMO you don't need to spend the money for a Propride or Hensley hitch with a 3/4 ton pulling a 25 ft. trailer. An Equalizer 4 pt. or Reese dual cam will do all you need. I have the Equalizer with a 3/4 ton, 30 ft. trailer and have never experienced sway.
On edit...Now that I know your trailer is 37ft. I will have to say I no longer have an opinion since I have no experience with a trailer that long. Best of luck.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
02-19-2019, 11:32 PM
02-20-2019, 02:17 PM
Very happy with my Reese dual cam sway weight distributing hitch.
02-20-2019, 03:47 PM
Trailer Park Supervisor
Very happy with my Fastway E2 trunnion bar hitch. Got the bars for 8000lb trailer/800 lb tongue weight. 350 bucks. Good value.
Yes, I drink the water!
02-20-2019, 04:25 PM
Make that X10
02-20-2019, 04:49 PM
Let me say that I am very happy with my Andersen hitch. It’s light weight and does a great job eliminating sway and transferring weight. Also, no greasing anything and no heavy bars.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
02-20-2019, 05:08 PM
X2
02-20-2019, 05:16 PM
I agree, Andersen is light weight, no sway, no grease, only weighs 50lbs
2019 RAM 1500 Limited ETorque 4X4 5.7 Hemi 8 spd 3.92 Axle ratio
2018 Grand Design 2150RB
02-20-2019, 09:37 PM
Thanks for all of the replies. Have been looking at the Anderson Hitch. Like the light weight and the reviews I have read have been good.
02-20-2019, 09:45 PM
waybeck2018
We have traveled many miles with the four point Equalizer. No sway, no wiggle. We like it on our 34 ft Tracer towed with an F-250.
2012 F-250, 6.7 Super Duty Powerstroke; 2019 291 BR Primetime Tracer,
Days camped in 2018-61
Looking Forward to Completing This Map Soon !
02-20-2019, 10:03 PM
The trailer is 37.3 feet and 11,342 lbs GVW. 13% if GVW is almost 1500 lbs of hitch weight. These numbers will disqualify, for your use, most of the hitches that were recommended above. I would recommend the Blue Ox Swaypro 1500/15,000 or the 2000/20,000. Over on the Grand Design Owners Forum where 37-38 TT ownership is common, this hitch gets a lot of praise.
Steve, Barb, and 5 daughters who love to camp
2017 Shamrock 23IKSS, Weight sticker: 5314 lbs, Equil-i-zer 4pt. 1,000/10,000
2006 Fleetwood (Coleman) Niagara: Sold
2004 Suburban 2500 8.1 liter, 4.10, tow rating 12,000, GCWR 19,000, Doorjamb payload: 2108
2003 Suburban 1500 Z71, 5.3/3.73, airbags, LT tires, Big Brake Upgrade, Prodigy P2
