08-18-2019, 08:25 AM
What is this?
6,000 miles in the mountains with 8-10% grades and I thought to check the brakes on my new wolf pup. Brakes don’t work. TV brake fuse is ok. Looked at the axle connections and expected splices. Instead there are these things that seem like fuse blocks. If so there are four of them!
08-18-2019, 08:46 AM
Can you hear the magnets activate when someone steps on the brake pedal? Do you hear the buzz? If so, do you have a brake spoon and know how to adjust your brakes by moving the star wheel?
I think those pieces are just weatherproof wire junctions.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
08-18-2019, 08:47 AM
Those are a type of wire connector. Have you checked for voltage there when brakes are applied?
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
08-18-2019, 08:55 AM
Do the brakes lock when you pull the breakaway ?
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
08-18-2019, 09:25 AM
What model brake controller do you have and does it display numbers when you manually activate it?
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
08-18-2019, 11:46 AM
Well hell nell
This is a case of “You know what you know but you don’t know what you don’t know wouldn’t you agree?” Thanks to the pin out diagrams here on this site I was able to determine that the trailer brakes are fine, those weird looking goobers are splice crimps. No power to the pin on the tv. Dealer told me I was good on brakes when I left the lot because I had the round plug factory installed. In Subsequent conversations with the service manager no one bothered to inquire whether I had a brake controller. I don’t. Found the plug and wire for one in the glove box. Duh all around.
08-18-2019, 11:52 AM
That was my gut feeling but I didn't want to come out and ask if you had one, so I asked which model you had to see if that might trigger an "ah-ha! Oh..." moment.
Glad the mysteries have been solved!
2013 Shamrock 21SS
08-18-2019, 12:24 PM
The connector in the pics are Scotchlok connectors. I personally don't like them but they certainly are helpful when you need a quick fix.
If you have the factory wiring pigtail adding a controller is quite easy. My suggestion for a controller would be a Tekonsha brake controller. I have found them to be very reliable and consistent. I have personally used a P2 and P3 but prefer the P3.
2013 Rockwood Freedom2381G
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
08-18-2019, 01:52 PM
WOW! Good thing you didn't drive in any mountains.
That's why RV newbies should join a RV forum BRFORE buying the RV.
They would learn what they should know, that they don't know, before they get on the road.
08-18-2019, 02:11 PM
Didn't read the OP, eh? [emoji6][emoji54]
2013 Shamrock 21SS
08-18-2019, 02:12 PM
So nobody is going to blame the dealer, ok I will. His dealer sucks, should have never ever let him leave that lot until they verified the brakes were working on the trailer. And if a dealer can't tell that a TV doesn't have a brake controller then they shouldn't be a dealer.
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
08-18-2019, 02:23 PM
[emoji32][emoji37]that's what I get for skimming the posts.
08-18-2019, 02:25 PM
OP You don't say what your vehicle is. Ford, Dodge I know have a pigtail behind the dash where the factory brake controller would be and a place to install a factory brake controller. You would also need to put the proper fuse in the fuse block out under the hood. I have done several Fords and one Dodge back when I was working.
Pretty sure GM products work the same way.
08-18-2019, 03:01 PM
Wow could have been a disaster .................... At least the TV brakes could stop both. Its real fun when you loose both TV and the trailer has no brakes.
Been there.
At least you found out before an accident .................
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
08-18-2019, 03:37 PM
My dealer absolutely verified I had a brake controller, it had power, and would control the brakes. We pulled in un-annoinced, looked at trailers, settled on a price, with one condition. We could take delivery in no more than three days.
When we arrived at the appointed time, they “took over” the Tow vehicle. Set up WDH, gave us a detailed walk-through, made me show them I knew how to drive, adjust the P2 controller, I knew where the fuses were, and I had some spare fuses. I’ve towed trailers with brakes for many years (about 35). I recognized the dealer cared and made sure we would not have a no brake issue.
Glad the OP discovered this before there was a mishap.
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
08-19-2019, 12:54 AM
My truck came with a plug in the glove compartment. My dealer told me it would be $200 to install a controller. I didn't believe their BS and found a plug and play cable on Amazon that allowed me to wire my P3 controller directly to the firewall. It took me 15 minutes to mount the P3 and hook it up. So if you haven't already installed a brake controller, get a Prodigy P3 and a plug and play cable from Amazon and install it yourself.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
08-19-2019, 05:35 AM
Go with the "Prodigy" and you don't have to install box on dash, install harness. Mount box to hitch, plug handheld unit into 12v in vehicle....and go. want to tow with another vehicle ? Plug handheld unit into 12v in other vehicle...and go.
08-19-2019, 05:41 AM
Kind of wonder what the TV is and what kind of weight on the PUP. If I was pulling a pup behind the GMC I use to have, I wouldn't have worried about trailer brakes.
08-19-2019, 08:30 AM
Their profile says a 4Runner.
2013 Shamrock 21SS
08-19-2019, 10:09 AM
Mopar Guy
it says wolf pup not Pop Up. so im assuming he has a small single axle travel trailer
Dave
2019 Grey Wolf 24JS- sold
1998 Holiday Rambler Imperial 41wds
