Old 05-02-2019, 03:21 PM   #41
Originally Posted by frank4711 View Post
Ram say's recommended 89 .... 87 OK .... I tried 89 can not tell difference???? what would you do???
Normal driving conditions you probably won't notice it. If you happen to do a lot of spirited driving, or tow a lot, you'll notice it. I'm on my third Gen 4 Ram 1500 with the 5.7. Yeah, I can run 87, and the engine will pull timing so you don't hear it pinging. I most likely won't notice it just driving around town, day to day type stuff. Unless I'm hammering on it, then I could tell there was a power loss, lack of throttle response. But I tow with my truck about 70% of the time. Mostly my bass boat all over NC, SC, TN, GA and VA. Without a doubt I can tell while towing. Towing puts a lot of added stress on the engine, keeps it in the upper RPM's where the power is, which generates more heat, which leads to pre-ignition if running lower octane. When I go to James River and back, about a 650 mile round trip for me, I'll see about 11 mpg running 87, while I'll see 14-15 mpg running 93. The engine just runs better, power is there when I need it.
This is a camper forum, right? I'd assume we're talking about what gas to use while towing.
2020 Ram 2500 Laramie Longhorn 6.4
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 05-02-2019, 04:12 PM   #42
Same as for not towing.
ppine is offline   Reply With Quote
Old 05-03-2019, 11:13 AM   #43
wicked1's Avatar
Had a 2014 F150 Crew SB EB 3.5 used only unleaded regular tried super makes no diff. I know the F150 with the new Raptor 3.5 and in the f150 limited requires SUPERbut for all other models regular is fine I never saw a diff with super so figure why waste the extra $
wicked1 is offline   Reply With Quote
Old 05-03-2019, 05:56 PM   #44
Shell highest octane when traveling. Real gas 89 octane here at home........the usual go to for dino fuel
RET.LEO is offline   Reply With Quote
towing
