Old 05-06-2016, 09:06 PM   #11
I agree. I am getting conflicting information about payload vs pin weight vs axle rating. For example: the ram 2500 has a payload of 1890, an axle rating of 7000, and a max towing of 16000.
How to calculate the actual amount that the truck can handle in a 5th wheel?
It can tow 16k, but only by the bumper? That doesn't make sense.
It can tow 16k, but only if the hitch weight is less than 1890? That makes no sense either as no trailer will balance that way.
Thoroughly lost at this point.
pprice01 is offline   Reply With Quote
Old 05-06-2016, 09:15 PM   #12
CWSWine's Avatar
Go here Towing Planner - towing capability calculators
You can exceeded the 16k tow with a TT but with a 1890 payload you are really limited to the 5er you can tow.
With 150 lbs passenger, 250 lbs 5th wheel hitch and 1890 payload:
You're adding approximately 400 lbs. to the truck. You have 1,490 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 5,960 - 7,450 lbs.
With a TT with 150lbs driver, 100lbs hitch and 1890 payload:
You're adding approximately 250 lbs. to the truck. You have 1,580 lbs. of payload capacity. Travel trailers typically have 10% - 15% tongue weight which gives you a maximum loaded camper weight of 10,533 - 15,800 lbs.
Huge difference!!!
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 05-06-2016, 09:17 PM   #13
Wobbles's Avatar
As I look around, it seems that most people say that 80% of your tow vehicle's max rating is safe.
Other people say to stay at/below 80% of max payload (making sure to include people, gear, and the hitch to the hitch weight of the 5er) - while using 20% of the 5er's GVWR as the guide for Hitch weight - not the Mfg listed hitch weight.
Lots of 5er options out there. Here's my weight table assuming my tow vehicle has a max towing of 16,500 and a max payload of 4,350 (reduced to 3,800 after including 450 for people + 100 for gear in the truck. Could always lower more for the actual hitch, but you get the idea.
Seems at 14,500 or below for the 5er GVWR I'm below 90% on max towing and well in the safe range for payload.
At 15,500 GVWR OF THE 5er I get a bit shaky for max weight (94%) but still under while only at 82% of payload.
Is this too risky for weight, or should I be OK given that the payload is what it is?
Am I calculating properly? Any other thoughts?
Thanks,
Paul
Interesting spreadsheet. Where did you source that from?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 05-06-2016, 09:23 PM   #14
davel1971's Avatar
Since when does a truck have the capability to tow twice as much travel trailer as with a 5th wheel? That makes no sense. 5th wheel capability is always higher.
David & Lynn
Old 05-06-2016, 09:25 PM   #15
dannyabear's Avatar
Interesting numbers, his sig line says 3744 cargo capacity, but in post it states
4350 max payload, which is it?
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 05-06-2016, 09:26 PM   #16
Put that together in Excel myself from data from each Mfg website, and added the calculations for GVWR and Payload against a ram 3500 megacab diesel.
Old 05-06-2016, 09:28 PM   #17
Not sure who this is meant for?
Old 05-06-2016, 09:33 PM   #18
dannyabear's Avatar
Truck runs out of payload with a 5th wheeler.
Danny & Darlene
Old 05-06-2016, 09:45 PM   #19
So, based on my table above, a 3500 SRW setup with the capacities listed would handle any of the 5ers listed?
Old 05-06-2016, 09:58 PM   #20
CWSWine's Avatar
Since with a 5th wheel you have to figure a average of 20 to 25% of the 5er weight is in the bed of the truck and becomes the limiting factor based on the yellow payload sticker and the what you put in the truck. A 15,000 lbs 5er have a pin weight between 3000 to 3750 lbs (20 to 25%)
Where a TT is 10 to 15% weight on the back of the truck and in most cases the limited factor is the max combined truck and TT weight (GCWR). A 15,000 TT would have a hitch weight of 1500 to 2250 lbs (10 to 15%)
Been that way for ever.....
5er, towing, towing capacity
