Old 10-20-2011, 11:49 AM   #41
MtnGuy's Avatar
I realize the 60 series tire will look better since it is wider, but I prefer a taller tire. You need to be careful in keeping the tires near the same width as you currently have, so it is sized correctly to your wheel size.
Old 10-20-2011, 12:36 PM   #42
This is the calculator I like to use. You can compare hieghts as well as widths. Tire size calculator
dstars99 is offline   Reply With Quote
Old 10-21-2011, 11:59 AM   #43
Chillbilly's Avatar
That is a good calculator for comparing the tire diameter and speedometer accuracy.
I just wanted everyone to know that I have decided to stay with the stock tire size. I have decided on Michelin LTX M/S2 tires in the stock P235/70R17 size. They are considered to be light truck tires and have the XL (extra load) rating of 2200 lbs at 41 psi. They are rated at 70,000 miles. When I get them installed, I'll post my feelings about these tires compared to the Hankooks.
Chillbilly
2013 Rockwood Signature Ultra Lite 8244WS
2015 Ford F250 Quad Cab w/6.2 Engine
Chillbilly is offline   Reply With Quote
