06-05-2015, 07:49 PM
What tires should I get on new truck?
We are considering buying a new truck to pull a bigger travel trailer. What size truck tire is best for towing? Is there a rule of thumb? What about all terrain tires? Dealer is trying to sell us several trucks with 18 inch and 20 inch tires. We want to tow a 7000 pound trailer (trailer and everything inside). Any information about this would be helpful. I don't want to totally depend on the salesman for this info, since his main objective is to sell a truck...not necessarily the one that is best for me. Thanks.
06-05-2015, 07:53 PM
Find out the replacement costs of each size tire. That's a great place to start you could be shocked at the costs for the same brand tire.
06-05-2015, 08:05 PM
Dee, we really need more information to provide better feedback. Are you sure about the 7,000 pounds? What is the tongue weight? How long is the trailer? Are you thinking about an even bigger trailer in the near future? Will the truck be a standard cab, extended or crew cab? Are you shopping at different dealers and when you do, ask to speak to the "truck guy" (most dealers have one salesman that specializes). Now to your original question - tire load range and weight capacity is more important that wheel size. Most 1500 series trucks now come with "P" rated passenger tires and you don't usually get LT tires until you move up to 2500 trucks.
Give us more information.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
06-05-2015, 09:22 PM
Thanks for your help! The trailers we are looking at are around 27 or 28 feet long and 5000 pounds with hitch weight of around 500. We were thinking of buying a GMC 1500...hoping that would be enough to pull that size trailer. We see the trucks can have different size tires and we want to make sure we pick one out with the right tires.
06-06-2015, 12:18 AM
There are more choices for 18" tires than there are for 20" for E load rating. But if you are buying a new truck, maybe be able to get the dealer to switch them out to an E rating.
Just glad to get away
06-06-2015, 02:34 AM
Just a member
You're prying open Pandora's box...
There are myriad sized truck tires that are suitable for towing, including the 18 and 20-inch varieties. However, there are many other variables that will determine how well one tire will perform over another. The basic rule of thumb is that the tire is certified and is labelled as being able to handle the load that your travel trailer (TT) will impart on your tow vehicle (TV). Now it gets complicated...
Many light trucks of the half-ton variety come equipped with passenger car rated P-Metric tires. That might include those 18 and 20-ich tires you referred to. There are a number of forum members (bless their hearts) that will insist that you can't safely tow a 7,000 lb TT with P-Metric tires and that these tires can contribute to trailer sway. They will further insist that you won't be safe unless you equip your TV with at least Load Range (LR) D or LR E tires.
Here's the complicated part: We've been towing a 7,000 lb plus TT for four years and 21,000 km, over hill and dale, with a half-ton, equipped with... yep, you guessed it, P-Metric tires. We don't have issues with sway save for the occasional 30+ MPH crosswind but at the end of day, the tires perform very well. At no point in our travels have I felt compelled to seek out a tire with a higher LR.
More complications: You and only you can determine what feels right as regards your impending TVs performance when pulling your TT. You may be quite satisfied with a 18 or 20-inch P-Metric tire equipped TV. Or, you might pressure the dealer to install a suitable LR D or E tire on the TV, just to be safe (Pandora's box). Notwithstanding, you must ensure that you have a good weight distributing hitch (WDH) installed with a good sway control.
The ball is in your court...
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
06-06-2015, 06:40 AM
Thanks so much for the information!! I have been looking at the GMC 2015 trailering guide and we hope to buy a CrewCab short box V-8 truck with 3.42 axle ratio. Thought I had read somewhere that if you have 18 inch tires you have to take 500 pounds off how much you can tow. (Is that true???) So I wondered if a specific tire was what I should make sure we have on the truck we pick out. We have been pulling a very light trailer with a GMC Acadia (with a towing package), so we really don't know anything about trucks. I appreciate everyone's input!!!
06-06-2015, 07:31 AM
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
06-06-2015, 07:51 AM
LT (light truck tires) are the only tire that should be on a pick-up truck for towing. The only reason P-metric tires are used on a light trucks such as a 1500 series trucks is that most people do not tow and want a car ride for their grocery getter.
The tire should be an "E" rated tire and the wheel should be able to support this load also. Some wheels sold for BLING and Flash will not support the given load placed on the tire when towing.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
06-06-2015, 08:15 AM
the price gap is starting to narrow between the 2, but 20s are still quite a bit more. Look at the load rating on the tires themselves on the trucks you are looking at, and/or on the sticker in the driver door jamb
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
06-06-2015, 08:32 AM
18 inch tires are better - I have P series and have had no problem with them. Lt's are heavier too I just see it as overkill IMO. 20's are low profile no good.....
I set mine to max pressure as described in the owners manual and all is well. 3:42 ratio on the rears is pretty low again IMO.
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
06-06-2015, 08:33 AM
Davel1971 I was about to say the same thing. Check the recommended rear axle weight rating and compare that to the max weight rating on tires. Remember that there are two tires i.e.(#3400 X 2=#6800). Now go get that truck and start getting your camp on!😃😜
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
06-06-2015, 08:43 AM
With my Ecoboost i had 20 inch wheels, P series when purchased. They held the weight when inflated to 44 psi as per manufacture recommendations. Even at 35 psi they did carry the weight but 44 stiffened up the side walls. I upgraded to LT tires and that was a huge stability difference and handling. I would recommend LT tires. I now have a F 250 and it has 18 inch LT Michelin's. I guess some trucks with P series 18 would have issues with load, usually earlier on with 20 inch wheels and P series this was the case.
B and B
06-06-2015, 09:38 AM
Thanks again for the advice. Does it matter whether they are 17 inch or 18 inch tires? Is one better than the other?
06-06-2015, 09:39 AM
Sorry ... did not see reply about 18 inch tires being better. Thanks.
06-06-2015, 09:45 AM
A question about bluwoo's comment...am I better off getting the V-8 (6.2L)with the 3.23 axel ratio or the V-8 (5.3L)with the 3.42 axle ratio? Is there a big difference?
06-06-2015, 09:49 AM
Bus Driver
x1000 - The best advise for your and others safety.
Are you sure a 1500 (1/2 ton) series is enough truck for your anticipated trailer? I think I would more consider a 2500 (3/4 ton) series with a 3.73 ratio(s) What will be to combined gross weight? Some RV dealers will tell you "Ya, you can pull it with that" as you beat the daylights out of your under-powered, under-equipped truck. You are spending money. Spend a little more and have your truck last that much more longer (if required)
06-06-2015, 10:57 AM
2006 Honda Goldwing
06-06-2015, 11:00 AM
Best advise on tires is LT (light truck) or Load range E. Stiffer tires pumped up to their correct pressure range make it easier to steer and corner and give me confidence when hitting a pothole or road debris at speed. And 3.43 gears is probably OK with modern 6 speed trannies.. better off with higher number (3.72 or 3.90 gears) will make climbing hills and keeping speed on hilly freeways much easier and will keep the tranny from hunting for the correct gear
2014 Shamrock 183
06-06-2015, 11:13 AM
Like Deaver said you may even look at a 3/4 ton.
Gear ratio is very important and for MPG lower number for towing higher number.
go to 13:03 and watch what happens with wrong choice to tow with. Also look at the capacity numbers on the window sticker should show higher towing cap with higher gear ratio. My tundra has a 4:30 ratio and that's standard for the tow package so look for comparisons between towing packages available.
Hope this helps!!
2006 Honda Goldwing
