Old 04-22-2013, 08:32 PM   #1
What tow vehicle are you using for 36CKTS?
Now that we have our 36CKTS ordered we must get serious about a tow vehicle. We would prefer a short bed, single wheel but getting real world numbers for weights is difficult. Also if you have weighed your 36CKTS would really help to have that. Hitch weight is very critical.
We did a search for this type info but results were disappointing so would really appreciate your input.
Thanks for your expert assistance,
Jim
UncleFudd is offline   Reply With Quote
Old 04-22-2013, 08:45 PM   #2
If you haven't gone nuts with options then the "real" weight should be really close to what the factory says...In my case I have the Touring Edition 36RE...factory specs state low 12000 reality is low 13000, factory pin is 2200, reality is 2360. Full Body Paint, Thermal Pane Windows, Gen Prep, 6 Point Leveling, 4 door fridge, TrailAire Pinbox, etc, etc, all add to the factory numbers.
_______________
2011 Ford F350 Diesel Lariat with Firestone Airbags and Ford installed Reese Elite 18K 5th
2011 Cedar Creek 36RE Touring Edition - Loaded
djkarau is offline   Reply With Quote
Old 04-22-2013, 08:49 PM   #3
FYI,
Trailer Towing Guides | Trailer Life Magazine
grayfox is offline   Reply With Quote
Old 04-22-2013, 08:51 PM   #4
Here's another...
Tow Vehicle Sizing
Old 04-22-2013, 09:03 PM   #5
Former Full Timer
Duckogram's Avatar
We towed our 36CKTS with a 2010 Ford F250 Crew Cab Short Bed 6.4L Diesel. There are no duallys in that configuration.
We weighed it EMPTY and we were at 2300 lbs on the pin. GCVW was 19,900.
What we also found was that we were 90lbs under the max tire capacity. Since we had 17" wheels, the highest tire rating you can get was E which maxed out at 3195 lbs. My DW has 90 lbs in shoes alone! So I picked up 2 18"wheels and some 4600 lb rated rubber and we were good to go except... We were now over our GAWR. Lots of folks are comfortable with that because the tires were the limiting factor. If I had a lower ratio rear axle it might have been better but the 3.30:1 yielded 7 mpg on our cross country and I only had a 26 gal tank. We also got blown all over the place with crosswinds and anything passing. It just wore me out.
We used a Pull Rite 2700 auto slider to save the rear window.
Now we have a 2012 F-350 6.7L Ford Diesel. It is a Super Cab Dually and it has the complete Ford 5th Wheel/Gooseneck
Tow options package(s). It is Rear Wheel Drive only but has the new RSC electronics along with all the usual Ford towing upgrades. My loaded pin weight is 3000 lbs and I am 100 lbs under max gross trailer weight. On the TV, I am way under everything. Last 3000 mile trip averaged 12.0 mpg and I have 37.5 gal. tank.
I would not tow at this weight with a SRW nor would I tow with a short bed again. But that is just my opinion.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 04-22-2013, 09:21 PM   #6
Iggy's Avatar
Jim
Jim
How many miles a year do you plan to use/drive your new Cedar Creek?
If you are planning long distances for your vacations I would suggest a Ford F-250 2 wheel drive duelly, short bed with the 6.7L diesel. If you get a short bed you will need a slider hitch but I feel you will find full size beds easier. Also consider the Ford in-bed 5th wheel mount from the Ford Factory. See the attached picture of my bed of my truck with factory RV package and sprayed in bed liner.
If you have the money buy a new one but if you find a good quality
Name:	2011 Ford  F-250 008.jpg
ID:	28722   Click image for larger version
Name:	2011 Ford  F-250 009.jpg
ID:	28723   Click image for larger version
ID:	28724   Click image for larger version
Name:	New Truck & Trailer 005.jpg
ID:	28725   Click image for larger version
Name:	2011 Ford  F-250 011.jpg
Old 04-22-2013, 09:29 PM   #7
Fulltime family RVer
Might I recommend, if you don't have the truck yet to do the math off of the gross trailer weight and worst case scenario? That way you're good to go no matter what the actual weight comes in at.
For instance, truck alone - I was shocked when I weighed and saw how much of my payload was eaten up by or add-one to the trucks hitch and people/traveling stuff (almost 1,200 pounds!).
Old 04-22-2013, 10:10 PM   #8
Former Full Timer
Duckogram's Avatar
Originally Posted by Iggy View Post
...I would suggest a Ford F-250 2 wheel drive duelly, short bed...
...Also consider the Ford in-bed 5th wheel mount from the Ford Factory.
Iggy,
I don't believe there is an F250 Dually anything.
and
The Ford factory 5th wheel/gooseneck mount package is under the bed, just like yours.
Also, it looks like your TV is a gasser with some tail sag. I have some old Timbrens that will fix that for you.
Old 04-22-2013, 10:52 PM   #9
Iggy's Avatar
Originally Posted by Duckogram View Post
Iggy,
and
Yes i meant to say F-350. I have a F-250. I stand corrected
No tail sag. It was the parked location that was weird.
I no longer have the trailer. I have a motorhome now
Old 04-24-2013, 04:09 PM   #10
Thanks to all for your input. The info and advice is a big help, just wish everything did not point to a long bed dual wheel truck.
Jim
