Old 09-20-2016, 04:20 PM   #1
Coachman 312BHDS
tbln930's Avatar
What Tow Vehicle For A 2016 3950BR 5ER?
My wife (God help me) is having me try to figure out what Ford TV is needed to adequately be able to tow a 2016 3950BR 5ER loaded. Probably a truck ages 2012- 2016 but not new. Please help. Thanks in advance.
The specs are:
Dry weight 13,085 (figure 15,000# loaded)
Hitch 2850-2950
40'5"
Truck
model? F250? F350?
Engine?
Rear end?
Bed length?
Tires?
Necessary only options?
2017 Open Range Roamer RF376FBH 42' fifth wheel
2016 F-350 Lariat SCrew 6.7L Turbo Diesel SRW - Extang Fold-up Hard tonneau cover - Husky 16k Fifth Wheel Hitch
tbln930 is offline   Reply With Quote
Old 09-20-2016, 10:25 PM   #2
CWSWine's Avatar
Safety is critical when towing an RV Trailer. This training video discusses the importance of understanding a Truck's ratings and how these ratings limit the size of the trailer that can be safely towed. You will be provided the tools and basic understanding needed to assist your endeavor to properly match a truck and trailer, so that you can enjoy RVing safely.
Matching Trucks to Trailers
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 09-20-2016, 10:39 PM   #3
Coachman 312BHDS
tbln930's Avatar
Thanks and watched it already. It still doesn't answer all of the specifics.
Old 09-20-2016, 10:52 PM   #4
grhodes50's Avatar
I believe that size trailer with those weights would require at least an F-350 dually diesel.
It's almost a catch 22. You won't really know your weights until you load the trailer, hitch up and weigh it. But then you can't do that until after you purchase the trailer.
My advice is to purchase a TV you know will be more than enough for the trailer your interested in. If the trailer ends up weighing more than expected, your covered. If not, well no one really complains about having too much truck.
Gary & Trish
2018 Nights Camped - 5
Old 09-20-2016, 11:00 PM   #5
CWSWine's Avatar
At 15,000 lbs you going to have a pin weight between 3000 (20%) and 3750 (25%) add to the 200 lbs hitch and couple people at 400 lbs you probably going to have hard time find a SRW that can handle the upper end and maintain the GVWR with in specs.
Here is tow planer with some of the number you posted above
Estimating Tongue/Pin Weight from Dry Weights - Towing Planner
You probably are not going to get gas that is rated to tow that much weight.
You boarder line needing a DRW if your weights end up on heavy side. If you are interested in staying with your trucks ratings and F250/2500 is out of the question.
I will just say this if you get a SRW F350 your are going to push the upper limit of the GVWR depending on how you load the 5er and what you loaded in the truck you could be over.
Old 09-20-2016, 11:03 PM   #6
Fulltime family RVer
Loaded, that's going to have 3,400+ pounds of hitch weight. Add in you, the wife, fifth wheel hitch and some gear in the truck and that's likely going to exceed the stickered ratings of many 3/4-ton trucks (250). The 250 will pull it, you just have to decide your willingness to exceed the stickers (which is a huge debate on RV forums).
For a 40' fifth wheel, I wanted the stability (perceived or otherwise) of a dually. But, going into this- I was a neophyte at towing. I know my friends in SRW trucks are regularly talking about getting a dually next. It's not for everyone, of course. But being our daily driver, you get used to it.
Personally, I'd look for something with a payload capacity of 4,000+ lbs.
I prefer a long bed. If I opted for a short bed, I definitely would have an automatic slider. Less thinking the better for me.
Old 09-20-2016, 11:10 PM   #7
CaptnJohn's Avatar
The specs are:
Hitch 2850-2950
40'5"
Truck
model? F250? F350?
Engine?
Rear end?
Bed length?
Tires?
The best I can do is give you my numbers on my 2016 F350 SRW 4X4 Lariat diesel short bed.
In order to get the 11,500 GVWR the 3.55 rear axel ($390) and 20" Michelin tires/wheels are required ($1390) are required. Max tow is 15,900 and the payload is 3434.
That dry hitch weight plus hitch, cargo, and passengers would put you over my payload. Loaded I'll bet you are over 3000# on the pin. Weight savings can be found by going to the XL or XLT trim and 2 WD. I added the Husky 5er tailgate which is at least 100# less than the OEM. You could save probably 500# by going to a gasser but I'd not want to pull that 5er with a gasser. If I had to go with that 5er I'd be looking at a dually. An F250 diesel will not have the payload to cover the hitch weight. My 2016 F250 XLT 4X4 diesel has a payload of 2247.
The newly designed F series are out. There are some great deals on 2016 models.
Good luck with your purchase choice.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 09-20-2016, 11:27 PM   #8
CWSWine's Avatar
I just went from a 14,100 lbs 5er that in within 120 lbs of GVWR and 39.5 foot long to a 2017 Solitude 310GK-R that is 12,100 UVW and 34'11" because I didn't like towing that monster with a truck with only 143" wheelbase.
Old 09-20-2016, 11:43 PM   #9
CaptnJohn's Avatar
The same reasons I said we could not buy the 42'7" Columbus that had everything on our wish list! Just not going to own another dually.
2016 F350 diesel
Old 09-21-2016, 06:27 AM   #10
Coachman 312BHDS
tbln930's Avatar
What is the issue with a duelly? That would be new territory for me.
5er, tow vehicle
