Closed Thread
Old 02-18-2015, 07:32 AM   #1
what truck should I buy
Buy the cedar creek 38rd fifth wheel
hitch weight-2190
axle dry weight-11250
unloaded vehicle weight-13440
gvwr-16190
cargo capacity-2750
dual axles-#7000
can I get away with a ford f 350 dissel single wheel
sweetlou is offline
Old 02-18-2015, 07:38 AM   #2
Buy as much truck as your wife will let you!
Still Kickin is offline
Old 02-18-2015, 08:02 AM   #3
well that is no problem...... have no wife do I need a dually
sweetlou is offline
Old 02-18-2015, 08:15 AM   #4
bigdaddy1
bigdaddy1's Avatar
Well, I have ordered a 3850FL Cardinal with about the same figures that you are showing and I am going to tow with either a 3500 or f350 crew cab short bed srw mainly so I can keep it in my garage. I have never tow with a dually but I can see the advantages of such a tow truck. Good luck!
BigDaddy1
2015 F350 CC Lariat 4/4 SRW
6.7 diesel
2016 3850RL Cardinal
bigdaddy1 is offline
Old 02-18-2015, 08:16 AM   #5
Mr. Dan's Avatar
Our rule if thumb here:
If you plan to tow a grocery cart and it's more than half full of dry cereal, you need this:
a Caterpillar D9T
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Mr. Dan is offline
Old 02-18-2015, 08:20 AM   #6
Witch Doctor's Avatar
hitch weight-2190
gvwr-16190
cargo capacity-2750
dual axles-#7000
You will be right at the max with a F250 go with a f350 and have some wiggle room. Single wheel f350 would be fine.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is offline
Old 02-18-2015, 08:27 AM   #7
hitch weight-2190
gvwr-16190
cargo capacity-2750
dual axles-#7000
I assume you are talking new. If so, yes.
dustman_stx is offline
Old 02-18-2015, 09:07 AM   #8
BamaBob's Avatar
I have been eyeing the same model.
The advice I have been given is this can be towed fine it's a Single wheel *as long as*
1. Your travels are mostly in states east of the Mississippi
2. Not doing a lot of steep grade mountain/high country towing
3. The areas you tow in are not susceptible to high winds
For us this was not the case - when we retire we want to visit the High countries of CO, NM, UT and we dream of driving the ALCAN so a dually is in the cards for us
Sent from my iPad Air using FRF App for iOS
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline
Old 02-18-2015, 10:07 AM   #9
My understanding is that DRW is worse in wet/slick environments, though. If this is true, it should be considered if towing in inclement weather is a possibility. Maybe others can confirm?
Old 02-18-2015, 10:13 AM   #10
asquared's Avatar
The dry weight of that trailer is toward the upper end of where my 3500 payload will allot so I would go with the dually to give you the added stability and extra payload allowance
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline
Closed Thread
truck
