Old 04-25-2008, 12:01 PM   #11
We just upgrade to Equalizer 1400 for our new camper from Reese friction sway and WD 1000 lb(?) bars .
After three hours driving with the Reese I was beaten up and pushed around by motor cycles passing us. I never could have let my wife drive with that happening.
The Equalize was recommended by the dealer over the cam style. Now we track well with the exception of the occsional big rig and gusty wind. My wife drives with no ill effects.
Go for the Equalizer if you still have the opportunity.
out4stlhed is offline   Reply With Quote
Old 04-25-2008, 03:40 PM   #12
Dodge Guy's Avatar
You will be extremely happy with the Dual Cam! I use it and I have no sway at all.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 04-27-2008, 01:29 AM   #13
S & V
Thank you all for your replys!
I think I am sold on the equal-i-zer, as it does seem to be a simple design and should be easy to install when I pick up the trailer. It looks to me that I would be drilling holes for the dual cam type, and I won't have my garage full of tools with me.
I think I am also sold on the Prodigy brake controller. Does anyone know where to find the factory connection for the plug in harness on 2000 GMC? I would like to find this before purchace so I know what I am up against. Also any tips on install would be appreciated.
Thanks again...Vince
wanners is offline   Reply With Quote
Old 04-30-2008, 11:43 AM   #14
TravelSoftballDad's Avatar
I went with the Prodigy P3 and love it. It un-plugs from the rear and is not hard wired. I take it out and swap with both the Suburban and Avalanche depending on which TV we are gonna use. I bought the second harness at local RV Supply for like $13.50. I'm fairly confident you will need the 'pre-2003' version that has a brown connection. Harness will simply plug directly into your brain near the parking brake. Have fun...easy install !!
2006 Avalanche 1500 w/6" lift
2007 Suburban 2500 4x4 w/4" lift
2008 Salem 26TBSS
P3 Controller
4 lil' ones & a Hottie for a wife
TravelSoftballDad is offline   Reply With Quote
Old 04-30-2008, 07:06 PM   #15
Hope this helps...
http://www.rvwholesalers.com/catalog...productid=1951
madkaw71 is offline   Reply With Quote
Old 05-10-2008, 10:37 AM   #16
Has anyone ever heard of a Trail Pac? Found a use one for $250. Is sway control and weight dis. Is this good deal?
choice spot is offline   Reply With Quote
