Old 03-28-2013, 10:22 PM   #1
What WDH setup should I go with??
TT - 2013 flagstaff 831BHDS 6900lbs dry 830 lbs tongue weight
TV - 2013 1500 Chevy Silverado 5.3 4WD 3.43 ratio HD cooling Crew
baketedc is offline   Reply With Quote
Old 03-28-2013, 10:24 PM   #2
jtstromsburg's Avatar
E4 equalizer hitch with built in sway control. 1000lb Bars, or maybe 1200lb bars depending on how you load your trailer.
jmo
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 03-28-2013, 10:59 PM   #3
Twisty's Avatar
I like the Reese Dual Cam with round bars.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 03-28-2013, 11:01 PM   #4
Would 10,000# work?
Old 03-28-2013, 11:12 PM   #5
ironj's Avatar
prob gonna want the 1200lb bars....that dry weight is gonna tick upwards real fast like in the real world....as far as wdh, how much you wanna spend?.....you can drop a grand and get a top of the line propride on one end, or a basic couple hundred dollar equilizer?? thats a big trailer for a 1500 series truck....personally i would run a straight line type of hitch at a minimum......
good luck sir!
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 03-28-2013, 11:13 PM   #6
Twisty's Avatar
OK, I'll ask...
What is the tow rating and payload rating for the truck?
2012 Surveyor SV264
NW Oregon
Old 03-28-2013, 11:18 PM   #7
ironj's Avatar
uh oh , here we go!! ......im so glad spring is here and the campers are out and about providing reading enjoyment!
Old 03-28-2013, 11:36 PM   #8
Twisty's Avatar
"thats a big trailer for a 1500 series truck...."
You started it! LOL
2012 Surveyor SV264
NW Oregon
Old 03-29-2013, 06:02 AM   #9
fmc
fmc's Avatar
We use a Blue Ox Sway Pro BXW1000. It works great!!
fmc is offline   Reply With Quote
Old 03-29-2013, 09:23 AM   #10
Looked it up. 1890 on the payload with 9500 towing for his truck. Looks like he might be right around his payload numbers when all is said and done.
I would suspect the 1000# bars will be just fine. Equalizer, Reese Dual Cam, Pro-Pride, Hensley, Blue Ox. All should do the trick. Hensley and Pro-Pride will cost you a lot more, but they eliminate sway instead of control it. Just have to decide whether the cost it worth it.
John & Amy
jnamadison is offline   Reply With Quote
