Old 07-14-2015, 11:23 AM   #11
daydreaming about camping
jeeplj8's Avatar
Originally Posted by racerx View Post
Wanting to buy a larger fifth wheel and want to be safe about it. Below is the information about the vehicle but all this information can be a bit confusing.
2008 Ford F350 Dually Diesel 4x4 with a 3.73 axle ratio
Truck weight 7,227
GCWR 23,500
GVCR 13,000
Max GCWR 5th wheel 18,800
payload 5,300
max towing 16,000
The fifth I am considering has a dry weight of 13,600 ( I am aware this is likely slightly higher than manufacturer states) and the trailer GVWR of 16,000. Trailer length 42 ft.
What say you, is the max fifth wheel I can legally tow with an estimated bed / cab weight of passengers and cargo of 500 lbs.?
remember that in MO the trucks plate must be a weight class for total of truck and trailer:
Registration fees for trucks, including all pickup trucks and all utility-type vehicles that are registered as trucks, are determined by your truck’s weight, and whether you will be using the truck locally (within 50 miles from home) or over a wider area. Your truck’s weight includes the weight of any other trailers or property that you might haul during the registration period.
Currently the largest non-commercial plate you can get is 24K - and you could theoretically go over that with your setup. I run an 18K plate - but with my trailer I would be way overloaded before I hit my 18K.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 07-14-2015, 11:36 AM   #12
Iwannacamp's Avatar
Originally Posted by cwswine View Post
trailer towing illegally
pickup & suv drivers towing trailers above legal capacity face liability issues
interesting
Iwannacamp is online now   Reply With Quote
Old 07-14-2015, 11:43 AM   #13
CWSWine's Avatar
Kansas tried to do that to me and I protested. Come to find out that is true for cargo trailers but RV are exempt from the requirement. I found several people already that DMV register the truck and trailer weight and now have just the loaded rating on the truck. They Kansas consider a exempt RV as one with a permanent mounted toilet. You might want to check and see if it is the same in your state.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 07-14-2015, 11:45 AM   #14
jeeplj8's Avatar
It is not. KS has a different system in place that does not require any plate for small trailers, and specific weight categories for larger trailers. MO treats every trailer exactly the same regardless of size/weight/type.
Old 07-14-2015, 11:48 AM   #15
I can't say I have ever seen a boat trailer with a WDH. I'm not even sure how you would attach the brackets to the tongue as the boat trailers tend to have the V set much further back than RV's.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 07-14-2015, 11:57 AM   #16
B and B's Avatar
Truck weight 7,227
GCWR 23,500
GVCR 13,000
payload 5,300
max towing 16,000
All lawyer talk threats of jail time aside.
What you have suggested for a trailer is within your trucks capacity! In Ontario 23,500 is the Max combined rating. With your Truck your loaded 5th wheel weight is around 16,000 allowing for your truck loaded estimate.
Happy Camping, take it slow and keep within the tire ratings.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-14-2015, 12:15 PM   #17
TN CDL
[QUOTE=ksignoles;922486]Also check your state laws regarding the need for CDL or special endorsement. TN has one if greater than certain combined weight and my combo is below about 900 lbs, otherwise I would have needed CDL.
I'm from Tennessee and you don't need a CDL (Commercial Driver's License) endorsement on a privately ownded RV. Only those professionally paid drivers. That's why we don't need to go thru weight stations or subjected to routine inspections and health requirements.
gfarmcafe is offline   Reply With Quote
Old 07-14-2015, 12:30 PM   #18
Fulltime family RVer
TRAILER TOWING ILLEGALLY
Pickup & SUV drivers towing trailers above legal capacity face liability issues
That article was about hitches and the need for a WDH over 5,000 pounds.
Plus, these references are for civil court with regards to negligence. As I said, there are no laws (aka, in a criminal court) that enforce weight limits. IMO, saying something is legal vs. illegal comes down to criminal courts. Lots of things can get you sued, but that doesn't necessarily make them illegal.
I'd be all ears if you can find me actual case proof that someone was convicted criminally of being over a manufacturer's weight limit.
And, again- I'm all for being within ratings. In fact, I just paid for an individual wheel weighing and have confirmed that I'm under all ratings except one (and because of that, I'll likely dump most of my fresh water for a while until we can get some more things managed). But, I dislike the statement that it's illegal. There's been no proof to back that up, whatsoever.
Old 07-14-2015, 12:32 PM   #19
TURBS's Avatar
1 ton van and trailer over loaded with shingles.
Just took pic.
Receiver hitch broke.
he's / we're lucky it happened right when he back in.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-14-2015, 12:49 PM   #20
jeeplj8's Avatar
It sounds like semantics - but citations for exceeding your plated weight, exceeding the state maximum for private vehicles, or exceeding the weight limit for specific roadways/bridges (all of which depend on specific jurisdiction) ARE criminal citations. They are almost all misdemeanor violations.
And while exceeding a manufacturer suggested restriction is not necessarily an independent crime, it has been used to show criminal negligence in manslaughter prosecutions. Full disclosure - this is generally in cases where the average person would question they safety of the load.
First day of law school they teach you: never use the word the never...and always avoid saying always.
weight
