Old 07-15-2015, 08:49 PM   #41
@Herk Thanks for finding my mistake and for the additional information.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 07-16-2015, 05:35 AM   #42
Herk7769's Avatar
One more point is that "airbags" and "Helper Springs" do not add payload capacity; just handling improvements. Typically the GVWR of a vehicle is more dependant on the truck's frame construction and axle mounting than the axle or tires.
HAM CALLSIGN - KC3FFW
Old 07-16-2015, 06:54 AM   #43
searay245se's Avatar
Originally Posted by dustman_stx View Post
First of all, I've never heard of anyone getting sued for being overweight with an RV- and I'll bet you most likely haven't either. On top of that, they'd have to prove that being overweight is what actually caused the wreck. In addition, my understanding is that "negligence" would mean a prudent person would have clearly known better. If I can walk into court with thousands of images of others towing RVs that weigh in excess of what a door jamb sticker says- and if you've travelled much you know this would be easily accomplished- it seems you'd have a hard time proving your case. I think you'd have to be blatantly overloaded- like someone mentioned earlier- to the point where Soccer Moms would be pointing and looking because even they could tell you were overloaded.
Happened a couple years back here in Ohio.Can't remember the specifics but guy was over weight and lost control on a freeway and I'm not sure of the outcome but I think because he was over he was sited for unsafe load and held liable but like you said I think he was way over and just because a thousand people do it it doesn't make it right.
Jeff & Debbie
2015 Tracer Air 255
2015 Ram Laramie Power Wagon 2500
searay245se is offline   Reply With Quote
Old 07-23-2015, 03:43 PM   #44
Source?
Old 07-24-2015, 03:17 AM   #45
Source?
I just remembered seeing it on tv but here are some sources that point to the liability of towing over weight.
TRAILER TOWING ILLEGALLY
Personal Vehicle Towing Liability for RV’ers — PersonalInjuryClaimsBlawg
Jeff & Debbie
2015 Tracer Air 255
Old 07-24-2015, 08:26 PM   #46
B and B's Avatar
Factory installed overload springs like my Camper Package do count as increased payload in my case.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-25-2015, 05:52 AM   #47
Herk7769's Avatar
If it is on the door post from the factory; that is true (and there may be more involved that just the springs).
If not; it is flim-flamery by the vendor/dealer.
Old 07-25-2015, 06:00 AM   #48
Just keep in mind, just because you may be 100#-200# over the lawyer stickers doesn't mean your frame, rear end, etc is going to break or blow up. Farmers have been and continue to overload trucks for years without problems. Just use some common sense.
IMO, no need to go out and spend $40-$50K for a bigger truck for 2-300#.
Old 07-25-2015, 06:08 AM   #49
Herk7769's Avatar
Knowing you are a few hundred over means taking the time to find out.
Most folks "assume" they are only a few hundred pounds over; but never check. They wind up being tens of hundreds overweight before long; and that is a horse of a different color.
If my tractor breaks down carrying a load of hay, I just leave it in the field till I can get it repaired. My family is riding along in that camper and sitting on the side of the road in 100 degree heat waiting for a tow is no fun at all.
Old 07-25-2015, 08:18 AM   #50
OC isn't talking about overloading a tractor. He means that trucks in the ag industry are often loaded substantially beyond what they were designed for without incident. Being involved in this industry for many years now, I can attest to this fact. In actuality, even if farmers/ranchers wanted to abide by the manufacturers suggestion they couldn't. The loads they carry are so complex and varying that they'd be living at the scales if they tried to weigh every time they hauled something. What they do is use common sense. They generally know how to load a trailer to have good balance and the heavier they load the slower they go and the more room they leave.
weight
