Old 04-27-2014, 06:14 PM   #1
oconomowoc's Avatar
Wheel bearing mpg
This is a technical question for someone who really knows their bearings. Will the gas mileage needed to pull a brand new trailer, with virgin bearings go up as the bearings are broke in? I imagine the larger tire sizes and the slower rpm will take longer but IF gas mileage goes up as they wear in how many miles do you need to get optimum performance?
2014 Shasta 21CK
Silverado 4X4
oconomowoc is offline   Reply With Quote
Old 04-27-2014, 06:25 PM   #2
acadianbob's Avatar
I would think undetectable . . . .
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 04-27-2014, 06:31 PM   #3
SKnight's Avatar
If adjusted properly, undetectable. They get very, very slightly smoother once worn in, but the energy needed to rotate the wheel is no different. It pales in comparison to sidewall flex and aerodynamics.
Old 04-27-2014, 06:32 PM   #4
Herk7769's Avatar
FIRST would be the aerodynamics and frontal area of the camper and second the trailer tires. ST tires are designed to have lower rolling friction and LT tires have more (since they are designed with a traction tread pattern).
By the time you get all the way down to bearings, you have already covered whether the truck's windows are up or down.
HAM CALLSIGN - KC3FFW
Old 04-27-2014, 06:43 PM   #5
davel1971's Avatar
if your bearings are so tight they are affecting gas mileage, they will melt out of the hubs in no time at all
David & Lynn
Old 04-27-2014, 06:54 PM   #6
Herk7769's Avatar
Ain't that the truth!
Old 04-27-2014, 07:07 PM   #7
VOE eh Lou? Not really funny tho'.
mpg, wheel
