Old 07-10-2015, 01:44 PM   #11
RollingDownTheHighway's Avatar
Does it stay that high? Mine spike at 205 at times when going up hills and depending on the outside temp, but then it drops to about 190-195 while rolling. As long as it doesn't hang up in those high temps, you should be OK.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 07-10-2015, 03:05 PM   #12
redcloud1's Avatar
TV is a Silverado 1500 Lt, I don't think it stays high.
redcloud1 is offline   Reply With Quote
Old 07-10-2015, 03:38 PM   #13
I tow with a '14 6L 1500 as well and it spikes to 205 at times, especially going up hills here in New England , but it drops right down. My 2010 1500 spiked to 210 -215 at times.
Old 07-10-2015, 03:42 PM   #14
The tranny temp will no doubt match the radiator temp as that's where the majority of the cooling takes place.
Old 07-10-2015, 04:25 PM   #15
jhoppmann's Avatar
My situation.
I have a 2010 Toyota Tacoma 4x4 (6400# towing capacity). My wife and I just bought a Rockwood Mini-lite 2306 travel trailer for camping. Our travel trailer is pretty light at 3800 dry, 4700 GVWR. Its 24' long and has a pretty big frontal area (8'x10'). We just took our first trip up to the Rim. My Taco complained a bit going up some of the grades. We were in 2nd a few times doing 50 at about 3800 rpms. Not bad but according to Torque the trans temps were eeking up there (230 pan, 245 torque converter). Engine temp only got over 200 once.
I have not run everything over scales but I know we have to be pushing it on rear axle (payload) weight and combined vehicle weight. I have an Equalizer weight-distribution hitch and Prodigy brake controller on the Taco now. On the flats and even downhill, everything is fine. No bob or sway and the trailer brakes work great. When we get to a hill is when things aren't so great.
I think the Taco would probably be ok as long as I keep an eye on the trans temp and change the fluid more regularly, but its the whole riding vs. driving thing. With a full-size I could enjoy the scenery without stressing out looking at Torque every few seconds to see if we need to pull over. So I'm thinking about selling the Taco and upgrading to an older diesel for less money.
2015 Rockwood Mini-Lite 2306
2012 F-250 FX4 6.7 diesel
10k Equalizer Hitch
jhoppmann is offline   Reply With Quote
Old 07-10-2015, 05:54 PM   #16
Islander's Avatar
Originally Posted by SpringerPop View Post
Islander, did you mean a 4R100 transmission? That's what your 2000 F350 should have.
Pop
Yes that is correct ...it does have the 4r100.
The engine is know to be bullet-proof...however, the tranny not so .
But having said that.... I went on the side of precaution and had it done prior to some long trips. I was not experiencing any problems with the transmission.
My transmission cooling does not go through the water radiator thus the 2 transmission coolers does a nice job for me .
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 07-10-2015, 06:16 PM   #17
PhoneDude 8289's Avatar
Ours is a 2008 tundra with the 5.7 and stock 6 spd trans with the factory tow pkg. Temp will always run 190º - 200º towing or not, takes a long time to get there, I do tow heavy at 9K+ GVW @ 15K+. A few times I have seen it reach 220º climbing some pretty good mountains with 95º+ air temp but doesn't stay there long. I asked the transmission tech at the dealer how hot was too hot for these He said if it reaches 230º better let it cool down. These are sealed units on the Tundra, no way to pop the hood and check the fluid, no dip stick. Toyota recommends service at 100K miles. Mine has had complete fluid flush at 50 and now 75K. Cost a couple hundred to get it done but I do feel better and I do tow heave for the truck. I use tow haul when towing and I downshift allot when slowing or going down steep grades. Still will shift like day one.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 07-10-2015, 08:41 PM   #18
Klbrown53's Avatar
When is it too hot
PhoneDude
I have same TV and I do the same thing. I did not start pulling heavy until 2 years ago but changed transmission fluid last fall at 60,000.
My heat gauge is just a simple C on one side and H on the other (2007). I have never seen it above "normal' which is the same place it stays unloaded. I am pulling around 8000 pounds. I pulled it up to Colorado late last year and from Estes Park to Durango up and over 11,500 feet and the transmission heat gauge never moved.
And I also drive and tow similar to you in Tow mode and in lower gears a lot of the time when it makes sense.
Klbrown53 is offline   Reply With Quote
Old 07-11-2015, 05:54 AM   #19
Originally Posted by Klbrown53 View Post
PhoneDude
My tundra came with the same temp gauges that you have. I added a scangauge II and get exact water, trans and intake air temps. The scangauge has many more monitors built in but I leave it set to monitor the fluids. The "C and H" gauge doesn't move much when compared to the scangauge. Below is a picture of the scangauge when I started the Tundra a couple of mornings ago.
Joe & Beverly
2014 8289WS lifted
Old 08-10-2015, 11:13 AM   #20
Klbrown53's Avatar
When is it too hot
Phone Dude 8289,
I want to thank you for our discussion on transmission temperatures. After you saying you used a ScanGuage II I did some research on them and liked both it and the price so I ordered one. I just installed it yesterday which was just plug and play. Then last night I figured out the Toyota codes for trans temp and put them in this morning. Seems to work like a champ setting in the drive way. I can watch both coolant temp and trans temp rise. Now just need to hook up the RV and go for a ride here in a few weeks......
Have you played with the horse power feature any? Curious how accurate it will be.
Thanks again.
PS
Looks like by your name you may be a telecom worker? I am retired from Lucent Tech/ATT/Southwestern Bell Telephone. Went to work for SW Bell in 1966 and retired in 1999 although I did continue to work in the telecom industry until 2011.
