Old 09-01-2016, 12:01 PM   #1
When unhooking trailer from ball.....
the coupler sort up snaps off the ball and I get a bit of movement of my TT while the jacks sits on my wood blocks. I thought it was going to fall off the blocks. It is chocked.
Any ideas what causes this?
I hope I am clear.
Lukegsdaddy is offline   Reply With Quote
Old 09-01-2016, 12:09 PM   #2
This is normal and is caused by where the ball is positioned in the hitch receptacle. There is a slight pocket forward of where the ball rests in the hitch. To prevent the "popping off" of the hitch, you can move the tow vehicle backwards just a tick to center the ball in the hitch before unhitching. Hope this makes sense.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 24 nights camped
Teamfour is offline   Reply With Quote
Old 09-01-2016, 12:17 PM   #3
I hope I am clear.
when that happens, your ball has solid contact with the front inside wall of the coupler, as you crank the trailer up off the ball that bottom lip of the coupler is forced up against the curve of the ball and when it reaches the halfway point it lets loose and that is the snap,...... if you put the vehicle in neutral and let it "relax", that should remove the forward force and somewhat allow the ball to center itself in the coupler cup and the snap will go away or be much less,....
fella10 is offline   Reply With Quote
Old 09-01-2016, 12:24 PM   #4
What Teamfour said... as well as... trailer ball sockets on some units fit VERY snugly. There has been quite the discussion with the ROO folks here recently about the socket being slightly undersize.
Also, make sure you use some kind of lube on the ball & socket.
I use a dry PTFE dry lube on my ball hitch trailers.
The coupler slides right off where before, sometimes the jack would lift the trailer & tow vehicle and I'd have to jump on the bumper to get it to release.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 09-01-2016, 03:26 PM   #5
I tend to pull my truck forward (after chockin tires and starting to lift tongue) to ensure the ball is all the way forward in the coupler. This ensures it isn't caught on the latch/release. The little bump is no big deal.
325BH is offline   Reply With Quote
Old 09-02-2016, 12:14 PM   #6
rcla2014's Avatar
Parking brake
I hope I am clear.
As long as you are on level ground, try not setting the parking brake on the tow vehicle but, MAKE SURE IT IS IN PARK. The TV will have a little play, usually and inch or two, and then the hitch ball will not be totally tight against either the front of the coupler or the latch. May not be the correct way to unhook, but it seems to work for me.
Hope this helps.
rcla2014 is offline   Reply With Quote
Old 09-02-2016, 12:14 PM   #7
we use our x-chocks before unhooking. when we had the tow trailer, and even now when we unhook our fifth wheel. the trailer won't move. we almost lost a trailer when we unhooked once and it was chocked with the plastic chocks that you place behind. and front of the wheels. the trailer rolled right over them and down a hill. My husband grabbed the tongue and pulled the tongue to direct the trailer to the hill side instead of over the hill. and yes it was being parked in a hill with just a little bit of an incline we took all the precautions, but the equipment (the plastic wheel chocks that I see lots of others using, didn't hold up
ValMelton is offline   Reply With Quote
Old 09-02-2016, 01:24 PM   #8
Chocks
Those plastic chocks do good to hold a golf cart. Get the big rubber nes from harbor freight.
pdqparalegal1 is offline   Reply With Quote
Old 09-02-2016, 01:35 PM   #9
E brake
I pull the tt emergency brake out, the one on the trailer frame' when un hooking. This keeps the tt on the blocks. A little extra security to the wheel chock. Just remember to push the brake pin back in after you un hitch.
waynebas33 is offline   Reply With Quote
Old 09-02-2016, 01:49 PM   #10
northstar1960's Avatar
you can do that but not sure it's recommended . to each his own when it comes to their own tt's .
northstar1960 is offline   Reply With Quote
trailer
