Old 04-30-2014, 06:11 PM   #1
a2cntryboy's Avatar
Wheres my trailer ?
I have a 2007 Chevy 1500 I Installed a 47294 Hopkins controller and a 47795 adapter but the controller does not recognize that a trailer is hooked up I can manually energize the controller and the brakes work when I probe the blue wire connection under the dash with a circuit tester the light comes on showing that a trailer is hooked up what's wrong here ?
a2cntryboy is offline   Reply With Quote
Old 04-30-2014, 06:34 PM   #2
puff's Avatar
Get someone to flip the switch or use some electrical tape to hold it in the on position then you can test the blue wire....I would not leave it on too long cause you could over heat your trailer side of the brakes.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 04-30-2014, 06:49 PM   #3
bikendan's Avatar
if you have the 1500 based on the GM900 platform, then there's a fuse in the engine compartment, that needs to be activated for the controller to work.
this happened on my 2007 Avalanche when i hooked up my Prodigy BC. nothing happened until the RV shop found out about this inactive fuse.
even the local Chevy dealership service dept. were unaware of it.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-30-2014, 06:57 PM   #4
a2cntryboy's Avatar
Do you mean the fuse may be missing?
My controller works it's just that it does not recognize that a trailer is hooked up.
Old 04-30-2014, 07:38 PM   #5
flaggstaff's Avatar
I bought same brake controller it done same thing took it back to store exchanged it for another hopkins 3 yrs later still using it
Sent from my SAMSUNG-SGH-I537 using Forest River Forums mobile app
flaggstaff is offline   Reply With Quote
Old 04-30-2014, 07:39 PM   #6
a2cntryboy's Avatar
I may have to do that.
Old 05-01-2014, 02:35 PM   #7
Experienced Newbie
On my '11 Silverado, I had to add a fuse and connect the factory wire to make the trailer brakes work.
Check the info at the link below.
http://www.etrailer.com/question-17258.html
Sent from my SM-G900T using Forest River Forums mobile app
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 05-01-2014, 04:37 PM   #8
a2cntryboy's Avatar
Name:	ImageUploadedByForest River Forums1398980182.415917.jpg
Is this the blue wire that goes to the rear
For the trailer brakes it is not connected to anything ?
Old 05-01-2014, 05:39 PM   #9
a2cntryboy's Avatar
Here is a new twist I connected the blue wire under the hood to 12v to check and see if it went to the rear for power for the brakes I hooked up my test light Click image for larger version
Name:	ImageUploadedByForest River Forums1398983719.949369.jpg
ID:	51378 but got nothing at the terminal but the terminal just to the right is supposed to be ground has the 12v from the blue wire that I connected 12v to to see if it was connected.
Old 05-01-2014, 06:19 PM   #10
a2cntryboy's Avatar
Wheres my trailer ?
Update all is good now connected blue wire under hood to blue wire coming from controller haver power to rear now. It's funny how something so simple can drive you insane now on to the next project.
Getting everything ready for the trip that shouldn't take longer than a week or two .
Oh and thanks for all the help everyone.
trailer
