Originally Posted by ronheater70
Kinda like a few people that might have an issue with their truck shutting down on the highway,only means its possible.
The use of 'possible', while true as you stated, applies to most anything...as anything is possible. When the occurrences are recognizable due to the number of them having been observed...
I don't have a dog in this fight and I'm not a fan boy. I love trucks and have owned Nissan, GMC, Chevy, Ram and Ford. When truck shopping, I research and test everything made that will meet my requirements. I even tested the Fords this year and my last truck from Ford was a real pain in the rear (related to the current 1.3 plus million recalled 2015-16-17 F150's). That recall included the 17 F250...I didn't know at the time but I found reports of it having the same issue. Ruled it out.
I like the 3.5. My only complaint was how they programmed the transmission with the 6 speed. I haven't driven one with the 10 speed.
I would be in disagreement with some on here wishing this motor into the heavy duty line and I'd be willing to bet it never happens. I remember towing really heavy with a 350 (210 hp). On the floor or near to it all the time. That work truck went 175,000 miles towing and plowing snow. The poor trucks final day was due to a collision. Those older, low stressed motors (and not just the Gm one) could take a beating. I think the key is the 'low stressed' part and the 3.5 is anything but that.
Putting that 3.5 in a truck that weighs 2000+lbs more and put a 14,000lb trailer behind it for 150,000 miles is not on Ford's list. The 2000+lb increased weight and air drag from the larger frontal area of the HD would require more right foot with an empty truck and no trailer. More right foot means the little motor is in the boost more and as we all know this motor starts to drink fuel under load. Also, considering the mpg when towing would not be much of an improvement (if at all-it might be worse) over the larger naturally aspirated v8 and you would loose engine braking...I don't see the improvement. But for 1500 duties with increased capabilities and MPG for folks needing a truck to fit multiple rolls...its hard not to see the love.
However, a twin turbo setup with a larger motor might happen with lower boost pressure, especially if big brother makes manufacturers include HD's into their MPG limit/average.
