Old 02-27-2015, 09:29 AM   #1
DDC
DDC's Avatar
Which truck?
We are considering making a change to a fifth wheel Rockwood 8289ws, we want to tow it with a GMC half ton max towing 5.3 with 3.73 rear end, where we are stuck is which box length to get either the 6ft 6 inch or the 5ft 8 inch anyone with any experience in doing this, we'd hate to go the wrong way.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 02-27-2015, 09:42 AM   #2
I would go with the 6'6" box strictly for convenience when not towing.
Old 02-27-2015, 10:16 AM   #3
BamaBob's Avatar
X2 what OC Says. You are still going to have to use a Reese Revolution hitch and you will definitely appreciate the extra cargo space.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 02-27-2015, 10:51 AM   #4
Have you checked your payload sticker to see if you will have enough truck for the pin weight? Just my guess but by the time you load everything up you'll be close to 1700lbs for the pin. Factor in you and whoever else and whatever else you put in the truck and it looks like you need a payload rating around 2000-2200lbs.
Not bashing the 5.3 but trying to tow close to 9000lbs with one seems like it's going to work it pretty hard.
Also the 8289WS is really cargo load challenged. Only 1268lbs for gear is on the real low side. That's also a 'dry weight' number. It will be closer to 1000lbs after it's shipped. By the time you load your normal stuff in you'll be maxed out on the tires and suspension.
Unless those weights from the FR site are a misprint I'd look for something different.
goduc is offline   Reply With Quote
Old 02-27-2015, 11:04 AM   #5
Have the Flagstaff equivalent and have pulled it over 40,000 in 3 yrs with no problems and only have a 3.23 rear end. Your pin wt estimate is not even close as even when we load ours to go to FL for 3 months, it only drops the rear 1-1-1/2" which I get back with the air bags.
Old 02-27-2015, 11:07 AM   #6
What was your pin weight when you last weighed you 5er?
Old 02-27-2015, 11:18 AM   #7
Have never weighted it!
Old 02-27-2015, 11:33 AM   #8
DDC
DDC's Avatar
The pay load is 2100 and since GM now applies the SAE J2807 standards this includes two 150lbs people and adds 70lbs for extras, so I see no problem with weight, I would also be running LT tires and Like OC I have no intentions to weighing it, if it gets overloaded it will show it and I don't expect to see that.
Old 02-27-2015, 11:39 AM   #9
Mr. Dan's Avatar
See if you can find this GMC half ton with the 6.2L engine. It's a beast...
... and if your trailer pin box is built right, you won't need a Reese Revolution hitch with the 6.6' bed. Look at the AndersEn Ultimate hitch for a little help with hitch weight.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 02-27-2015, 11:43 AM   #10
The trailer comes from the factory with the Reese Revolution and doesn't need or require anything but the Reese 16K hitch.
truck
