Old 11-24-2013, 08:11 AM   #41
jd-ford-hd's Avatar
Gear Ratios
Rear gear ratios are too often overloooked. With the OD and new double OD transmissions, I would always order the lowest (highest number) ratio available. The New 2014 F250 has a .67:1 OD final ratio in the trans. The math: 4:30 X .67= 2.88. If you're old enough, think back to the time when there were no OD transmissions.! Would you have ordered a new truck with a 2.88 rear end?!!? Probably not. Also consider that all the newer trucks are sitting on much taller tires than they used to.
"IF IT AINT GOT A MOTOR, I AINT INTERESTED"
jd-ford-hd is offline   Reply With Quote
f250, truck
