Old 10-05-2018, 08:15 PM   #41
BandJCarm's Avatar
Originally Posted by koller1509 View Post
The only legal way to have a gasoline tank in the bed is a auxiliary tank with the pump and hose and then fill it like normal. It is illegal and dangerous to install a in bed transfer tank for gas and plumb it in to the fuel system. As stated above you can get a direct replacement larger tank.
Transfer Flow Trax3 is illegal?????????????????????????????????????
Says who?
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 10-05-2018, 09:47 PM   #42
Go Prepared for any eventuality. Can't have too much gas, water, or food.
Everything written by this author is not claimed to be fact nor fiction and may be considered seriously altered depending on the libation being consumed at time of writ.
2012 FR Stealth 2714 Toyhauler.
2017 Ford F 250, 4x4, Super Cab, 8' bed, 6.2 gas motor.
Various Desert Toys including a Rzr XP Turbo.
ADVtraveller is offline   Reply With Quote
Old 10-05-2018, 11:46 PM   #43
Always bring extra diesel for the tv. Usually around 10 or 15 gallons.
poriggity is offline   Reply With Quote
Old 10-06-2018, 08:28 AM   #44
Retired JSO's Avatar
When we had short bed diesel Ford trucks, about 30 gallon tanks, we carried extra fuel for long trips. With the Ford 6.2 gas, never a problem. The long bed Ford diesel trucks have 48 gallon tanks so extra fuel is not needed.
Retired JSO is offline   Reply With Quote
Old 10-06-2018, 08:41 AM   #45
CAT-RN's Avatar
I think I can easily make it across the US and back!! Click image for larger version
Russell
CAT-RN is offline   Reply With Quote
Old 10-06-2018, 08:45 AM   #46
BandJCarm's Avatar
I'm still trying to figure out why it was said automatic flow tanks are illegal............
FROG AR-0019-242
Old 10-06-2018, 09:45 AM   #47
More than likely for gasoline...not diesel.
babock is offline   Reply With Quote
Old 10-06-2018, 02:20 PM   #48
stansoper's Avatar
I tow a 35' TT, have 25 gal tank, & avg 8 mpg (6.0L Gasser). I am paranoid about running out of gas. I plan to get gas every 120 to 160 miles. I plan my gas stops using Google Maps and Street view to make sure I have easy access in and out of the gas station. I do not carry extra gas.
stansoper is offline   Reply With Quote
Old 10-06-2018, 03:35 PM   #49
I don’t carry extra gas since I have a 35 gallon tank in my F250. What’s aggravating is I can only get 30 gallons in it when the gauge shows empty. Not sure if I can push further after the display shows zero miles left on the tank.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 10-06-2018, 03:55 PM   #50
Your gauge is what's not accurate. I have the same issue with the 36 gallon tank in my F150.
Old 10-06-2018, 03:56 PM   #51
You can push it further.
If it's a newer 250 there is a TSB available to replace the tank and the pump for more accurate readings from the Low Fuel Warning system.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 10-06-2018, 04:01 PM   #52
I’ll check that TSB. Thanks for the tip. It’s a 2016.
Lee and Anne
Old 10-06-2018, 04:25 PM   #53
TSB only applies to 2017 34 gallon tank.
Lee and Anne
Old 10-06-2018, 08:38 PM   #54
koller1509's Avatar
Says who?
For gasoline yes and the federal government says so!!
You can gravity flow or pump diesel and its legal but gasoline is a big no no!!!
That's why no companies make a gasoline transfer tank any more!! You might want to re-read my post.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 10-06-2018, 08:40 PM   #55
BandJCarm's Avatar
Hmm. So why is it legal for diesel and illegal for gasoline?
FROG AR-0019-242
Old 10-06-2018, 08:44 PM   #56
koller1509's Avatar
Re-read my post - never said they are illegal - said it is illegal to use them for GASOLINE!!!
Larry
Old 10-06-2018, 08:46 PM   #57
BandJCarm's Avatar
OK, OK! Sorry! Gas is illegal. Diesel isn't. Got it. Wow.
FROG AR-0019-242
Old 10-06-2018, 08:47 PM   #58
koller1509's Avatar
Diesel is not as volatile. Every transfer tank will have the same warning - not to be used for gasoline. I didn't make the rules I'm just trying to educate someone who asked the question. Using a transfer tank for gasoline is illegal and dangerous but to each his own.
Larry
Old 10-06-2018, 08:49 PM   #59
BandJCarm's Avatar
And I appreciate being educated. Always. Seriously.
FROG AR-0019-242
Old 10-06-2018, 09:12 PM   #60
NMWildcat's Avatar
https://www.transferflow.com/regulations
You can easily have gas transfer tanks as long as they are not tied into the vehicles fuel system. If they are under 110 gallons you don't need a bulk fuel license in most states.
It gets tricky when you tie your auxiliary tank into your fuel system. Gravity feed is definitely not legal. Auto transfer with pumps and valves is legal for diesel, questionable for gas.
We use both gas and diesel manual transfer tanks on the farm trucks. The ones with a pump and a nozzle to fill other vehicles, or your own.
We used to use the auto transfer tanks, but they were too problematic. Manual transfer works just fine and is simple to install and move from vehicle to vehicle. And you don't have to worry about what the DOT reg really means. I don't think even they really know.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
gas
