Old 08-29-2012, 09:37 PM   #161
jtstromsburg's Avatar
Just bought a 05 F250 4x4 CC lariat V10, to replace my 04 1/2t suburban with the 5.3. Should pull my 7000lb tt much nicer! always been a GM guy, but found a great deal on this truck. Bet a 5er is in our future now too....
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 08-29-2012, 09:55 PM   #162
Originally Posted by pwrstroke2012
Hi waterrat, when you say you have "rear wiggle" is that on your TT or TV? If it's your TT it could be anything from too light of tires on your TV to your hitch set up. It may even be due to "P" rated tire on your avalanche instead of LT tires. I am not an expert by any means but it sounds like you are at the max for your TV which is hard on your truck and hard on you and not the safest set up. I was in the same boat as you as to spend money to upgrade a already overloaded TV and or do it right and safe and get a truck made to tow your weight. I started this thread to help with users in making the tough decision of upgrading from a 1/2 ton to 3/4 or 1 ton and hearing real life experiences and not theories.I went from a 1/2 ton gas to a 1 ton diesel and couldn't be happier with how it tows, almost effortless and I have a similiar weight TT as you. It sounds like a lot of users that did upgrade found good used diesels that they are very happy with and didn't pay alot. Good luck.
I have the stock P rated tires on the truck. Good news - I need new tires this next month. So thank you for the suggestion on replacing with LT tires.
I'm glad to hear that almost no one regrets upgrading their TV. I just had to replace the wife's vehicle this month, so it'll be awhile before it's my turn again. Thanks for all the suggestions and input!
WaterRat75 is offline   Reply With Quote
Old 09-02-2012, 01:22 AM   #163
Just picked up my replacement TV for my 1/2 ton Dodge Ram it's another Ram. 09 2500 sport with the Hemi. For me the gas vs diesel debate raged on in my mind for a long time but choosing another gas motor was right for me. I think this truck will pull my TT alot more comfortably on the highway as well as safely. Another 1K pounds added to the payload over the 1/2 ton is a quantum leap.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 09-02-2012, 07:57 AM   #164
Brigitte
boubou's Avatar
LT tires made a huge difference in the handling! No more squishy, floaty feeling and I feel safer as well.
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 09-02-2012, 08:14 AM   #165
phat phrog stunt crew
P series tires are usually designed for passenger cars, hence the "P". LT is for light truck. p tires will ride smoother, but lt's will take the weight.
dwaynerz is offline   Reply With Quote
Old 09-02-2012, 01:24 PM   #166
I pull my 40 ft. 5 slide fifth wheel with an 05 f250 4x4, may add airbags next year but the diesel pulls it with no problems, I average 60-70 mph and get 10-14 mpg depending on the area.
Blueridge40 is offline   Reply With Quote
Old 09-02-2012, 06:31 PM   #167
Swaggler's Avatar
[QUOTE="WaterRat75"]
Just a suggestion...when you have the LTs mounted, make sure they use new valve stems that can handle the load. My P-metric valve stems couldn't handle the 80 psi that my new LT's are rated at.
Always believe that you will ultimately succeed at whatever you do, and never forget the value of persistence, discipline, and determination.
Swaggler is offline   Reply With Quote
Old 09-02-2012, 07:30 PM   #168
Brigitte
boubou's Avatar
[QUOTE=Swaggler;246573]
I hear you! didn't think of that in time and it pisses me off!
pisses me off because I should not have to think or worry about about this stuff. new tires, the garage should suggest the different options. Never mind, they didn't even know how much psi I should put in for for towing! they told me just what's on the door.
Superglide 2700
Timbrens
Old 09-13-2012, 06:10 PM   #169
Good to hear the LT's worked. Peace of mind towing is nice.
pwrstroke2012 is offline   Reply With Quote
Old 09-13-2012, 09:13 PM   #170
i dont run mine at the 80psi they say to. that is the MAX pressure. i run mine at 70, towing and empty and seem to be getting good treadwear, but they are only 3000 miles old.
16 " michelin mtx lt tires. best 900 bucks spent ever.
