Old 04-26-2014, 02:25 PM   #21
Originally Posted by BlakeB View Post
Im not sure why anyone would want to grease the equalizer's bars and brackets so they don't squeak. That noise is those bars doing there job and greasing them is making them not have friction. Am I wrong on this?
The Equal-I-Zer is NOT friction sway control. The noise is the noise, and has nothing to do with sway control. The Sway control is a byproduct of proper weight distribution and leverage of the hitch head to the ball.
I used the teflon ball lube (Reese) on everything and it tamed the noise pretty well.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 04-26-2014, 06:53 PM   #22
GABandit's Avatar
Read the website about 4 point control. It does say that the friction
Points is what helps the sway.
[B]2014 Rockwood 2306 with Murphy Bed
2011 Chevrolet 1500
GABandit is offline   Reply With Quote
Old 04-26-2014, 07:17 PM   #23
We just put one on our F150 pulling a Windjammer and love it. Much better than the sway bars and weight distribution system we had before.
Fixitman is offline   Reply With Quote
Old 04-26-2014, 08:13 PM   #24
mamentt's Avatar
After having two breakdowns with our Reese hitch. I got the equal-i-lizer 4 way hitch installed in Souix City SD on trip to visit family. BEST, move I ever made.
The hitch is so much easier to use and no problems with sway control. Very Happy with hitch.
Mike A
Camped 82 days in 2014
mamentt is offline   Reply With Quote
Old 04-26-2014, 08:40 PM   #25
X2
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
Great Laker is offline   Reply With Quote
Old 06-10-2014, 09:01 PM   #26
TheFlagGang6's Avatar
We have an equalizer and it has been easy using once setup. A question though: can you upgrade the spring bars from 1000# to 1200# by simply replacing the bars or do the 1200# bars require a different hitch head?
TheFlagGang6
2008 Flagstaff 831QBSS
2005 Ford F150 FX4
2005 Ford Excursion Eddie Bauer 6.0l Diesel
TheFlagGang6 is offline   Reply With Quote
Old 06-10-2014, 09:24 PM   #27
BlakeB's Avatar
Really? campingwilliamsons you couldn't be more wrong. (Unless there is another Equalizer company out there) This is taken right off of Equalizers website.
"The Equal-i-zer hitch's rigid bracket design provides two points of the 4-Point Sway Control. Our innovative rigid trailer brackets serve two purposes. First, they work in conjunction with the rotational friction sway controls to reduce trailer sway. Second, the forward and back friction of the hitch arm on the bracket serves as a secondary sway control system. The sway control brackets work much like two "add-on" sway bars, but with more sway stopping pressure and less hassle. The sway control brackets are the innovative link that makes the Equal-i-zer hitch 4-Point Sway Control system so effective.
Put them all together and you have 4 points of positive friction working for you. Take your towing to the next level with Integrated 4-Point Sway Control™."
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 06-10-2014, 09:34 PM   #28
I've had two. Currently using one for a 21fbrs and had another one for a Sunline 2363. I wouldn't leave home without one & don't care about the noise.
00buck is offline   Reply With Quote
Old 06-10-2014, 09:39 PM   #29
Platokidd's Avatar
If I remember right...
You can just change the bars 10k to 12k. Going to the 14k is not a option as you would need a new hitch head. I went from 10k to 14k and needed everything.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 06-10-2014, 09:47 PM   #30
dieselbobcat's Avatar
I have contacted the factory.... the load bars are different dimensions for each size. You need to replace the head as well...
Had the same idea when we upgraded to our new TT... right at the top end of the 1K/10K head...
2014 Rockwood Ultralight 8312SS Diamond Edition
2016 F350 Lariat Ultimate Super Duty Crew Cab 4X4
Northern NJ - God Bless America!
dieselbobcat is offline   Reply With Quote
equalizer, sway
