Old 06-10-2014, 09:53 PM   #31
another_newfie's Avatar
You will a new hitch head to go from 1K to 1.2K bars.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 06-10-2014, 10:01 PM   #32
Platokidd's Avatar
Looks like I was mistaken
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 06-10-2014, 10:05 PM   #33
TheFlagGang6's Avatar
I appreciate the responses. I kinda thought I'd be replacing the head but was hoping not!
TheFlagGang6
2008 Flagstaff 831QBSS
2005 Ford F150 FX4
2005 Ford Excursion Eddie Bauer 6.0l Diesel
TheFlagGang6 is offline   Reply With Quote
Old 06-10-2014, 10:13 PM   #34
Originally Posted by campingwilliamsons View Post
The Equal-I-Zer is NOT friction sway control. The noise is the noise, and has nothing to do with sway control. The Sway control is a byproduct of proper weight distribution and leverage of the hitch head to the ball.
I used the teflon ball lube (Reese) on everything and it tamed the noise pretty well.
This Post is 100% wrong!! Youroo!!
youroo is online now   Reply With Quote
Old 06-10-2014, 11:21 PM   #35
All, clearly I made a mistake on this one. I had somehow combined the methods of the equalizer and the Hensley together. I apologize for that...
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 06-11-2014, 04:31 AM   #36
Who Dares, Wins
doc73's Avatar
Hold on, campingwilliamsons....
OK now that everyone had to call you out...
I have had the Equalizer since we got our new trailer earlier this year. After towing to Georgia and back to PA what a night and day difference. We had come from a curt (sp?) WDH we got from Cabelas years ago when we had a popup.. It sucked compared to the Equalizer! No more sway when getting blasted by the semi's. It did make some funky noises but I spray the contact point with some dry lube and it seemed to help a bit. After 1000 miles of towing I tuned it out now.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 06-11-2014, 04:54 AM   #37
DaGrinch's Avatar
Bought my Equal-I-Zer as part of my deal when we purchased the '08 Roo. I check the torque on the nuts every year and give it a new coat of paint. Forget the lube, keeping the bars and L-brackets clean and covered in paint will keep the moaning and groaning down to a minimum, IMHO, and still allows the spring bars to function properly. Lube reduces the effectiveness of the sway control if placed on the L-brackets.
I've now moved on to a larger TT and I kept the Equal-I-Zer. Still performing like new.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-11-2014, 06:00 AM   #38
Platokidd's Avatar
I use /paint MowerGUARD™ - Graphite Undercoating for Mower Decks and Blades on the L brackets and bars ends. The graphite embeds into the steel. Clean, slick no mess re-spray once a month or as needed.
For the hitch head friction area, ball I use wheel bearing grease and SLIP Plate® Aerosol mixture. I also clean the head and re-apply as needed.
Im a graphite guy what can I say. Both work good imo. The noise is not that bad when the parts are lube and it lets me know its working. And the best part of the noise ,scares the crap outta fdw
I check the torque once a month.
nights of camping
Seasonal
Old 06-11-2014, 06:37 AM   #39
We have had two Equal-i-zers on two different trailers. Fantastic hitch. I agree that NOT lubing the L-brackets helps with sway control. I don't mind the noise.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 06-11-2014, 07:53 AM   #40
BlakeB's Avatar
The L brackets can definitely be sprayed with a lubricant...but it DOES reduce sway control. Anything other than a heavy lubricant won't last all that long on these hitches anyway. May as well just keep some fresh paint on the L brackets
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
equalizer, sway
