Old 06-18-2014, 09:51 AM   #61
Platokidd's Avatar
Originally Posted by thebrakeman View Post
At 1175lbs, I would seriously consider the 1400 lbs unit! In my opinion, being so close to the limit can have the spring bars acting too "springy" which I believe is what contributes to the "porpoising" phenomenon that everybody hates. 200-225 overrated is nothing for a WDH. I have 700lbs TW and have to use the 1000lb Equalizer (they don't make an 800). Great combo.
Not to mention, if 1175 is your estimate, you could easily go over 1200 based on packing fluxuations. If you call Equalizer customer service, I'm sure they would recommend the 1400.
Finally, the 1400 would protect you if you decide to upgrade in a few years.
X2
My lacrosse spec said 875 tongue weight. So I put my 10k hitch on that I had.
Only to scale out at 1150 lbs. With nothing added gear wise.
Upgraded to 14k..works gr8!
Sent from my DROID RAZR using Forest River Forums mobile app
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 06-20-2014, 09:46 AM   #62
member
All I can say is amazing !!!! used the new equalizer 4 pt hitch for the first time and it towed perfect had 25/30 mph cross wind and never missed a trick no sway at all not even with Tractor trailers passing. For two years I have been battling my Reese duel cam with no success so if your on the fence about this hitch I agree with most others get it. It makes towing a pleasure and hitching and unhitching is really easy Thanks for all the good info on this forum you people helped me make my rving more pleasurable and safer.
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 06-20-2014, 09:53 AM   #63
Citrus County, Fl.
GL1800Rider's Avatar
Super fast delivery
Ordered my Equalizer WDH on Tuesday and it arrived yesterday (2 days). Thanks to those that suggested RVWholesale!!
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
equalizer, sway
