Originally Posted by thebrakeman
At 1175lbs, I would seriously consider the 1400 lbs unit! In my opinion, being so close to the limit can have the spring bars acting too "springy" which I believe is what contributes to the "porpoising" phenomenon that everybody hates. 200-225 overrated is nothing for a WDH. I have 700lbs TW and have to use the 1000lb Equalizer (they don't make an 800). Great combo.
Not to mention, if 1175 is your estimate, you could easily go over 1200 based on packing fluxuations. If you call Equalizer customer service, I'm sure they would recommend the 1400.
Finally, the 1400 would protect you if you decide to upgrade in a few years.
X2
My lacrosse spec said 875 tongue weight. So I put my 10k hitch on that I had.
Only to scale out at 1150 lbs. With nothing added gear wise.
Upgraded to 14k..works gr8!
Sent from my DROID RAZR using Forest River Forums mobile app
