Old 01-12-2013, 07:40 PM   #31
(Kim)
Labzy's Avatar
I'm too comfy sitting on my behind ATM to go get the CAT papers.
I have done the math on the numbers and it all adds up. It's just the way it is.
You have hit upon my 'sore spot' with our Ram though. Crappy payload. 1100lbs.
No matter how we slice it, we will always be over on the weight rating.
DH is 250lbs, I'm 120, DD 70, dog 75. Add in tongue weight, bikes and the other crap in the back and we are over 1100lbs.
But I'm not complaining.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 01-12-2013, 07:50 PM   #32
Your crew cab has a back seat that is just a little bigger than the regular quadcab and you have a bed shorter than 6 feet? Thats the reason the payload numbers are low the added weight of the larger cab is subtracted from the payload. They do the same thing with a Cummins vs Gas motor in the 3/4 tons the gas motor has a better payload than the Cummins due to the weight of the motors (Cummins is much heavier).
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 01-12-2013, 07:56 PM   #33
(Kim)
Labzy's Avatar
Yes, and we had some other additions at the dealer. Running boards, tonneau, and bed liner was added after yellow sticker so our payload is probably even less (<1000lbs?)
Live and learn I guess.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 01-13-2013, 10:32 AM   #34
Brigitte
boubou's Avatar
towing Jayco Eagle HT 23.5 weighing at 6800 lbs loaded with the 1500 Ram 2010
I don't know mileage because the trip odo is off since the Michelins LTX/AT2 are a big higher. Tows fantastic, no problem going up or down hills.
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 01-13-2013, 10:41 AM   #35
Originally Posted by ryand View Post
I tow with 2011 Ram 1500 Crew cab with the 17" wheels and 3.93 gears. Pull a Coachmen TT that has a loaded weight of 7k. The truck does not lack power even on hills and will accelerate with no problem. I do wish Dodge had higher payload numbers on the 1500's. By the time I load up gear and people the heavy Tounge weight puts me almost to the payload cap....Lets not forget the 32g gas tank. Hmm.
EODtruck- We have darn near the same setup. The trailer sounds like it might be a twin!
Your right! Identical setup!
EODtruck is offline   Reply With Quote
