Old 02-05-2016, 12:03 PM   #31
When the weather and road conditions are good (primarily level with few hills) I use it with an F150 Ecoboost towing a Windjammer 8029W. Keep it around 62 mph and get 10+ mpg.
Magdeep is offline   Reply With Quote
Old 02-05-2016, 12:07 PM   #32
KMANUEL74's Avatar
9k mile trip this past summer with my F150. Used it constantly. Put transmission in tow mode and no problems
KMANUEL74 is offline   Reply With Quote
Old 02-05-2016, 12:09 PM   #33
Briorick's Avatar
Originally Posted by Justice12t View Post
I use it a lot while towing. I read the manuals and was not able to find anything that said I shouldn't, unless I missed it...
I keep it in tow/haul and let the truck decide what it wants to do and intervene when necessary. Just what I do, I am not saying it is right or wrong...
Same here. Although, I put mine in 3rd ( less gear searching ), Tow Haul is on and set the Cruise to approx. 63mph, when road and driving conditions are good. Sit back and enjoy the ride.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 02-05-2016, 12:14 PM   #34
MacDR's Avatar
I always tow with Cruise Control on..Only requirement is Drive Pavement..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "14"
You can find us: Egg Harbor Campground 7/9 - 7/11
MacDR is offline   Reply With Quote
Old 02-05-2016, 12:39 PM   #35
I use mine except in curvy mountains, it creates alot of excess noise from the right seat.
Rick_Geneseo is offline   Reply With Quote
Old 02-05-2016, 12:48 PM   #36
I use it all the time except going up a hill. My truck is a stick shift so I do the shifting :-)
2016 Rockwood Ultra Lite 2604WS
2004 Dodge Ram 2500 CTD 5 speed Manual 4x4 Laramie
2005 Ford Mustang Convertible
1993 Jeep Wrangler YJ IL6 4.0 lifted (love it)
Happy Trails All!!
roaddiva is offline   Reply With Quote
Old 02-05-2016, 01:13 PM   #37
redcloud1's Avatar
I will use it but only when it's flat not when there are hills. Was towing in the mountains last year with the cruise on in my Silverado 1500 and it caused the computer to shut the engine down to to 4 cylinders. Thank goodness I have tuner programmer that I was able to reprogram the computer back to stock.
redcloud1 is offline   Reply With Quote
Old 02-05-2016, 01:13 PM   #38
Out of control cruise
2008 F-250 PSD. While towing on cruise control I had to accelerate quickly and truck went into passing gear........... wouldn't come out of passing gear. Stepped on brake nothing, turned cruise off nothing just continued to accelerate. Finally stood on brakes and turned the key off. After stopping tried to start and the motor and it revved immediately, turned key off. After 20 minutes everything was OK and we continued the trip, without cruise control.
Returned the truck to Ford dealer and factory tech reps couldn't replicate the problem. "Anomaly". Dealer service manager said I was lucky advised if it ever happened again shift to neutral and if the engine blows they would deal with it. He also told me turning the motor off wouldn't always work as a diesel doesn't have an "ignition" system and can run with the key off in certain circumstances. So be careful with cruise control and towing.
2008 F 250 6.4 PSD 4x4 Pullrite 15K
2013 Crusader 325RES
cascade is online now   Reply With Quote
Old 02-05-2016, 01:19 PM   #39
The first thing I do after I crank the truck is put in tow haul and turn the exhaust brake on and once I get up to my set speed is set the cruise.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 02-05-2016, 01:24 PM   #40
On our '08 GMC Sierra 1500 with 5.3 and 4-speed auto, cruise control was the pits on even minor upgrades. The trans would shift into "passing gear" and stayed there even after cresting. I learned that if I left it in cruise, but accelerated with the gas pedal when starting up a grade, it helped from over revving. But if there was a memory lapse, it went into the ridiculous high revs. This TV has the trailer tow button on the shift lever. It was pretty annoying to drive.
We traded for a '13 Silverado with 5.3 and 6-speed auto and it made a world of difference. We were reluctant to go 6 speeds because of some bad reviews. Driving on normal hills, the transmission behaves. On steeper upgrades I may use the gas pedal along with cruise or take it off.This also has the trailer tow button on the shift lever.
What I have noticed, that using cruise, the engine is revving lower and gas mileage improves . For instance, on a quasi level roadway holding the gas pedal steady at say 65 mph, then actuating the cruise and taking the foot off the pedal, it maintains the set speed, but the rpm reduces about 500 rpms and the instance economy increases. I have noticed that if not using cruise, it seems difficult to maintain a steady speed. And I have found that, once the cruise is set and deactivated to slow down, it is wise to get back to speed with the pedal before engaging cruise to prevent a downshift. Example: cruise set at 65 mph engaged at 55 mph will cause the trans to try to get to the set speed rapidly, downshifting several gears.
These results are from towing the same 7,000 lb GVW cargo trailer fully loaded. MPG on either TV ranged from 9-11 MPG, depending on towing conditions over a distance of 1,700 miles between Florida and Wisconsin.
PenJoe is offline   Reply With Quote
towing
