Old 10-16-2011, 08:10 AM   #1
Dodge Guy's Avatar
WHOA! brake issue found and fixed...long
Well after checking, adjusting, cleaning, and fiddling with my trailer brakes for the last few years I finally found the problem.
Let me backtrack a little. When we bought our trailer I noticed from the begining it never did stop good, but we went from a light weight shorter trailer to a fullsize heavier trailer. so I thought it was just the nature of the beast. we put it in as a seasonal for a year with 1 road trip during that time. that`s when I felt there was an issue with the brakes. I thought maybe it was my brake controller(Prodigy) at the time so I installed my old controller and it performed the same, so I reinstalled the Prodigy. I adjusted the brakes and it didn`t make much difference, a little if any. then the next year when we took it out of indoor storage (seasonal was up in april). the brakes seemed OK but slowly degraded over the next couple of trips. I adjusted the brakes again, and it helped a little.
A few years ago I replaced the trailer end connector because it was a little sloppy in the TV plug. during this time I also went through all the electrical connections for the brakes, checked out OK. the brakes were a little better, but it may have just been my imagination thinking I found a problem. 2 years ago I went around and inspected, greased and installed new seals all around along with adjusting the brakes. it was just so-so. and I dealt with it. well after one panic stop on our trip to the Smokey`s last year, enough was enough!......as a side note I Gotta give credit to 4 wheel dics brakes. looking back the X`s brakes handled probably 70% of the stopping during that time. anyway I did some searching and found there were people with some brake issues with Lippert axles/brakes, mainly bad brake magnets so I went with that.
We are leaving for FL. in a few weeks so I decided to replace all 4 brake magnets. I went around cleaned all the backing plates, lubed all the areas where the shoes contact the plate, lubed the swing arm/actuator for the magnet, sanded the pads and cleaned up the drums. don`t know if it makes a difference or not, but the replacement magnets were about 25% larger than the ones I replaced. I test drove it and at first it didn`t stop well, because I needed to "burnish" in the magnets (let them seat themselves to the drums) after approx. 5 miles of applying the trailer brakes at high and low speeds the the trailer now stops with authority! I can actually feel it pulling on the back of the X! when I backed inmy driveway I could feel the heat from the brakes from all 4 wheels. they never got hot before! I can now actually lock up the trailer brakes at low speeds on dry pavement with the manual lever. I couldn`t even get them to lockup or drag on gravel before! and no I don`t have them set so they lock up when braking hard! I can`t believe I dealt with this for all these years. I`m willing to bet the magnets were getting weak when they got hot, electrical wise, not heat from the brakes. I now look forward to stopping and "knowing my trailer is back there!"
And as a side note.....I was reading through my Trailer Life (tonite actually LOL) and someone sent a letter into RV action line about a problem with their trailer brakes not stopping well. they too replaced their magnets along with the drums and it fixed the braking problem. and guess what axle manuf. it was? Lippert! luckily my frame is still holding up LOL!
I just figured I would throw this out there. figuring there was someone else with a braking problem they couldn`t pinpoint. I did find a seal that was slinging a little grease and it got onto the magnet surface on the drum, didn`t make it to the shoes or drum braking surface. even though this would hinder braking performance it wasn`t leaking before when I was having braking issues. so it was a lucky catch on my part! and why we should all do PM on our RV`s
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-18-2011, 09:49 AM   #2
Excellent writeup! I'm sure it will help someone in the future.
Gotta go campin!
Old 10-18-2011, 11:23 AM   #3
Wanna Be Camper
SaskCampers's Avatar
Nice find !!!
Our V-Lite has pretty much the same symptoms as you described here and has had since it followed us home for the first time. Our previous 33ft Edgewater would lock all 4 no problem as well as easily stop the entire truck and trailer with the manual lever but not this one. I guess I will be getting some new magnets in the spring as the trailer is put to bed for it's long winters night so to speak.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 10-18-2011, 12:01 PM   #4
Villa Estate 392FLFB
The_Stuff's Avatar
guessing thats why i cant lock up my trailer brakes either!
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 10-18-2011, 12:14 PM   #5
TURBS's Avatar
Im not sure how you guys are adjusting your brakes but simple backing up and hitting your manual brake lever numerous times normally adjusts the brakes.
When i bought my 5er 2 months ago the brakes were not adjusted properly so while on pavement on my long driveway i started backing real slow and hitting the manual lever about the 3rd time they were adjusted perfect .
just and fyi that you dont have to crawl under and do it by hand thats for the birds and its hard to have a beer under the trailer anyways .
Old 10-18-2011, 01:17 PM   #6
MtnGuy's Avatar
Many trailer campers do not have auto-adjusting brakes. As a matter of fact, this is the 1st that I have heard that any camper does. Mine definitely do not.
Old 10-18-2011, 01:39 PM   #7
Wanna Be Camper
Mine does not have auto adjusters either. ANd why no beer under the trailer? It is much quieter as no ones seems to want to come under there with a person.
John & Deb
Old 10-18-2011, 05:32 PM   #8
acadianbob's Avatar
I adjusted my brakes tighter this year because they weren't doing much even at full signal from the controller. It helped. I think they could use more but I'm nervous about getting them too tight. I've heard about counting the clicks but I'm not always confident that the adjust has moved; or the tool just slipped. When you spin a free wheel, how much resistance should there be? How many revolutions should you get on the wheel with a good twist?
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 10-18-2011, 06:06 PM   #9
MtnGuy's Avatar
I have heard that you adjust until you can't turn the wheel, the back off 6 clicks. You might hear the brake rubbing slightly at that point.
I too wonder if the brake tool has slipped, messing up my count.
Old 10-18-2011, 06:15 PM   #10
sherdep's Avatar
Good Info - Have a safe trip to Florida Dodge Guy - You will be in my neck of the woods - where ya gonna be camping at in Florida if I may ask?
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 10-18-2011, 06:57 PM   #11
Wanna Be Camper
From page 14 of the AL-KO manual
http://www.al-kousa.com/pdf/alkobrochure.pdf
Brake Adjustment
Lift trailer as outlined on page 13
Service Preparation. Do not
remove the wheels or hub/drum assembly.
Locate the adjusting slot at the bottom of the backing plate and
remove the protective cover.
While spinning the wheel, use
a standard brake adjusting tool or the
blade of a screw driver to rotate the
star wheel until there is a heavy brake
drag.
Loosen until the wheel turns
freely about 3/4 to one full turn.
Replace the protective plug to
keep dirt and moisture out.
Repeat procedure for other
wheels. Never adjust just one brake.
It is recommended that all brakes on
the trailer, or at least both brakes of
one axle, be adjusted at the same time.
John & Deb
Old 10-18-2011, 09:33 PM   #12
Dodge Guy's Avatar
Thanks, Staying in Disney at Fort Wilderness!
As far as I know, no trailer with electric drums uses auto adjusters. and something else I learned is that only one of the 2 brake shoes gets used when stopping. one shoe for forward and one for reverse. unlike a car with hydraulic drums that uses a wheel cylinder that pushes out on both shoes.
Old 10-19-2011, 08:00 PM   #13
sherdep's Avatar
I stayed at Fort Wilderness - very nice campground - the golf cart rentals were like $68 a day, which was kinda expensive when you are on a limited budget. We walked and used the bus to get around.
Funny thing is I only live about 30 to 45 minuted from there depending on traffic.
Good Info
Old 10-19-2011, 08:37 PM   #14
Dodge Guy's Avatar
Ya, we`ll be in the parks most days so no golf cart for us. it would be a waste of $$$$. I also have a friend we may try and visit when we are there, they live in Plant City.
Old 10-19-2011, 08:47 PM   #15
sherdep's Avatar
It was a waste of money so we rode the bus.
If it wasnt getting cold out I would suggest going to the pool - they have a nice slide there - even the kiddy pool has a slide as well.
Have a safe and Enjoyable trip - we now resume to be back on topic of the brakes.
Old 10-27-2011, 10:34 PM   #16
TURBS's Avatar
These are my 6000# never adjust brakes just so you all know I wasnt feeding ya a line !
if you look closely the cable across the front pulls on the lever just barely visible behind the right shoe .
Old 10-28-2011, 07:00 AM   #17
MtnGuy's Avatar
Very interesting. And it looks as though it still has an adjustable star wheel.
Thanks for the followup.
Old 10-28-2011, 01:12 PM   #18
Dodge Guy's Avatar
Thanks for the pic! I have never seen or even heard of them before.....very interesting. now if they could make them so that both shoes do the stopping it would make the brakes that much better!
brakes
