Old 03-12-2015, 03:13 PM   #1
KenHwy61's Avatar
Who's right?
I am having a friendly little debate with my local Ford manager about the towing capacity of the 2014 f-150 with max tow and max payload. I read the specs as 5000 trailer/500 tongue without a W/D hitch and 11,300/1130 when a W/D hitch is used. He says its 5000/500 with a step bumper hitch and 11,300/1130 with the special max tow/ max payload receiver hitch. He says using a W/D hitch only adds further to the capacity but I don't believe this is correct.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 03-12-2015, 03:31 PM   #2
Actually, he is right to some small degree. The step bumper tow rating IS right about in there... 5000/500, but you're talking apples and oranges. It just so happens that the straight tow max on the hitch receiver is also 5000/500, w/o a WD hitch, so in that regard you're 'more' right than he is. ;-)
Does that make sense?
On edit: I forgot.. a WD hitch will 'NOT' add further towing capacity over your rated 11,300/1130. It's required over 5k, but you should not exceed the max rating.
rana is offline   Reply With Quote
Old 03-12-2015, 03:36 PM   #3
fonzie's Avatar
As Yarome said your both right to some degree. Here's rating on my bumper hitch and wd hitch.....
ID:	71212   Click image for larger version
ID:	71213   Click image for larger version
Fonzie
Old 03-12-2015, 03:57 PM   #4
KenHwy61's Avatar
The reason we are having this debate is though all the other truck specs are more than adequate to tow my 9000lb Aviator, I believe the 1400lb tongue would overload the receiver even with a W/D hitch. The manager believes that I am reading Ford's spec sheet incorrectly and the 1130 is the dead weight tongue rating for the hitch. I told him I thought I needed a class 5 hitch to carry that much tongue weight legally, which to the best of my knowledge are not available for the F150.
2012 Ram 2500HD CTD
Old 03-12-2015, 04:33 PM   #5
vinmaker's Avatar
Why are the numbers so far off for towing capacity? I find it hard to believe that by simply using a WDH, one can more than double the towing capacity. I thought the engine, tranny, and such were major components used to determine towing capacity. Is the OP saying that his engine and tranny can tow 5,000lbs but if he uses a WDH, then the engine and tranny can tow 11,000 pounds?
ROFL. I feel all turned around in the woods here. What am I not getting?
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 03-12-2015, 04:50 PM   #6
KenHwy61's Avatar
By using a W/D hitch you do double your capacity. Just look at Fonzie's photo of his hitch ratings. Just don't ask me why!
2012 Ram 2500HD CTD
Old 03-12-2015, 05:02 PM   #7
When you are doing a straight tow you are relying heavily on the rear axle, suspension, and tires of your TV. When you use a WDH hitch you are displacing weight across ALL axles (TV as well as your trailer) evenly.
So.. a rough and dirty example... say your hitch is completely up to the task, but your rear axle and suspension is only rated for 6500 pounds. Thereby limiting your tow/load capacity to the maximum rating of your rear axle. Displacing the tow weight over all axles, your rear is maybe only taking 3500 of the load.. the front axle is taking on another 3000.. the trailer axles another 3000. Get my drift?
So maybe you have a max tow capability of 12k, but that capacity is limited by the individual component characteristics of your TV and trailers suspension and tires.
Old 03-12-2015, 05:12 PM   #8
KenHwy61's Avatar
Thank you. Makes perfect sense. Moving some weight back to the front axle is a good thing. Its hard to steer if you're poppin' a wheelie!
2012 Ram 2500HD CTD
Old 03-12-2015, 05:21 PM   #9
I would really take a close look at your weights. I'm sure you probably don't want to hear it, but you might be biting off a little more than an F150 can chew safely.
I'm assuming the 9000lb and 1400lb tongue weights are dry? If so, you'll most undoubtedly be well over max once you're loaded up. Just sayin...
Old 03-12-2015, 05:25 PM   #10
fonzie's Avatar
I think he has 2500 HD chevy, he was just discussing with Ford manager...?? you know mine can pull more than yours kind of stuff...
2012 Chevy 2500HD
A dear wife
1 high-schooler
2 Boomerangers
11 more years 'til retirement
Fonzie
