Old 06-08-2016, 03:52 PM   #21
I go RV'ing not Camping
jgourlie's Avatar
The long and short of it is that the van will tow the load. You aren't going to win any land speed records and will struggle on the hills.
You can change your rear axle ratio with a new set of gears to 3.73 or 4.10's and that will get you more pulling power for less than $1,000 installed.
So the question is how much do you tow vs how much driving do you do unloaded?
If you only tow 1% of the time and drive lots unloaded than you might want to keep your 3.42 highway gears. If it is closer to 50-50 if it were me I would change out the gears because $1,000 is cheaper than a new truck
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 06-08-2016, 04:02 PM   #22
Oklahoma Proud
MillerTime's Avatar
Originally Posted by mrpep View Post
Not sure I understand what you're getting at ... Please explain
#1. I was saying you're van is probably heavier than you think
#2. A lot of v6 engines now have more power than that v8, so you will be very under powered
#3. With that engine, trans, gear ratio you will most likely have an unpleasant towing experience and a very reduced service life of the vehicle.
Old 06-08-2016, 04:09 PM   #23
Left Coast
The 4L60E trans is a glorified TH 350.....If you decide to use van for towing, and need a trans, there are quite a few after market updates for that trans.....get 'em..
Old 06-08-2016, 05:26 PM   #24
mrpep's Avatar
So far I towed this trailer once and it was actually a breeze but it was only 150 miles and no hills. I'm starting to get a bit concerned. I only camp maybe 5 times a year max and usually a few hours away.
mrpep is offline   Reply With Quote
Old 06-08-2016, 07:42 PM   #25
5 times a year fairly close to home I wouldn't be too concerned. If you plan on having the van another 15 years then maybe.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-08-2016, 08:04 PM   #26
mrpep: Remember that GM's numbers are probably based on what they sent out the door at the factory - a stripped down van that someone is going to add a bunch of stuff to. That bunch of stuff is what's adding the weight.
2011 Traverse LT, 3.6L, FWD
Old 06-08-2016, 08:05 PM   #27
mrpep's Avatar
I called the weight station today and they're open 24 hours a day so plan on going Saturday early morning
Old 06-08-2016, 08:59 PM   #28
jgourlie's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
X2
Old 06-08-2016, 10:42 PM   #29
mrpep's Avatar
I was thinking of going a good 900 miles away to black hills South Dakota but think I might pass now
Old 06-18-2016, 11:33 PM   #30
mrpep's Avatar
So I added a trans cooler and a gage so that I can observe my trans temps. If my temps are under lets say, 190 is it safe to say that I am ok ? I still have not had a chance to weigh my vehicle by the way.
axle
